Cisco Switch issue....I'm new to Cisco and so I need a little help with setup a trunk
So I did configure 2 switches for trunking but they are unable to ping each other.  Please help.  Not sure what I'm doing wrong.
Switch 1 - Configuration
Switch#show run
Building configuration...
Current configuration : 1646 bytes
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
enable password cisco
ip subnet-zero
interface FastEthernet0/1
switchport trunk allowed vlan 1-100
switchport mode trunk
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
switchport access vlan 50
switchport mode access
no ip address
interface FastEthernet0/24
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch 2 - Configuration
Switch#show run
Current configuration:
version 12.0
no service pad
hostname Switch
enable secret 5 $1$5Aku$zFReGOOhdtOg9V1nU8PKQ/
ip subnet-zero
switchport trunk allowed vlan 1-100,1002-1005
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
switchport access vlan 100
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
switchport access vlan 99
interface VLAN1
no ip directed-broadcast
no ip route-cache
line con 0
transport input none
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
Switch#
14 Replies 14
marce1000
 - Wether the designated interfaces have become trunk links can be verified with 'show interface status'  ; but ping is unrelated to trunking. Usually you will give every switch an IP address on it's management interface, hence resulting in reachability trough ping.
M.
Abhishek Das
Which IP are you trying to ping? You need to configure IP address for VLAN1 on both switches then only you can ping.
Abhishek
I was trying to ping the IP of the computers.
Ping from PC1 with IP 192.68.100.100 to PC2 with IP 192.168.50.50 but it didn't ping - Transmit failed, general failure.
In the config's posted neither switch has an IP address or a default gateway.  Create a vlan (layer 2)  Create an SVI of the same vlan and assign an Ip to it.  Then create a default gateway if you want to ping anything off of the subnet used for the vlan's.  I assume there is a router somewhere?
Oh and be sure the SVI  (Layer 3 vlan interface) is no shut.
No router, just testing switch to switch
These two computers may be in different subnets depending on the subnet mask configured on them.
If you put both computers in the same network they should be able to ping each other.  I'm hoping it's just a typo on PC1 but try this
PC1
192.168.100.101
255.255.255.0
GW 192.168.100.1
PC2
192.168.100.102
255.255.255.0
GW 192.168.100.1
If these two pc's are connected to interfaces configured for switchport access vlan 100 on each switch and the trunk allows vlan 100 then you may be in business.
Awesome
I can ping..........YESSSSS
Now, how can I ping from 192.168.100.100 to IP 192.168.50.50
What if I have multiple networks and need them to access the same printers and the same file server
 - Beyond the scope of the forum but in the domain of study-and-learn....
M.
You need a routed interface for each network, ie layer 3 or IP.  You will need to enable the SDM routing template and ip routing.  I think this thread and the link at the bottom of it has what you're looking for but it is based off of 2960's.
If you want to learn more networking make sure to have a solid understanding of Layer 2 vs Layer 3.  What we made work was just a Layer 2 connection.
https://supportforums.cisco.com/t5/getting-started-with-lans/can-two-switches-pass-different-vlan-traffic-between-each-other/td-p/2505755
AymanMunassar
First, check the ports on the switch that you used to link it to the computer are on the same VLAN.
For example: computer A ---- Switch ----- Switch ----- computer B
Both A and B ports on the switch must be on the same VLAN.
Second: check that you have created the VLAN of question on all the switches.
Third: Make sure that the trunk links are allowed to transfer the VLAN in question.
Yours scinerely.
AymanMunassar
Actually, you cannot ping between switches because they work in layer 2. Layer 3 switches are exceptional. So, if you want to check your work, link two computers into your switches in question and then give each computer an ip from the same mask. Finally. use the ping.
No you can, assuming you have created an SVI.
The switch would also contain an ARP table.
Martin
I am talking apart from L3 switches. Look at his output, he does not have any SVI.
I see what your saying, originally it read as you need a L3 switch to ping another node.
