cisco switch simulator
norberto_cammayo
Community Member
Can anyone give or donate to me a cisco switch simulator. Tnx
desai.jaideep
Level 10
Level 10
I am sorry, you need to purchase it.It wont cost u more seeing the offering.
Check out the following links:
(1)www.boson.com
(2)www.semsim.com
Rate the post if it helps.
JD
JD,
Thank you for giving me the link to cisco simulator. It will help a lot. God bless u and your family.
Can u give me ur mail id?
JD
sean
Level 6
Level 6
Your best bet would be to start purchasing routers and switches if you plan on advancing your certs and career. You can always build on them. I would start with a 1710 (get one on ebay for about $130) as you can max the mem and do advanced items with it such as intra-confederation eBGP and VRF-lite. I would also recommend a 2950 so that you can do dot1q in your labs. These items can be used for your home internet connection in addition you your labs. I feel that you will get more benefit out of something like this, as it is not limited like a simulator is. Plus, it can last you a lot longer when you are trying to do labs that there is not a simulator for.
Hope this helps.
