Cisco Switch WS-C2960X-24TS-L IOS Discussion.
I have cisco Switch WS-C2960X-24TS-L and in the switch have c2960x-universalk9-mz.150-2a.EX5.bin" this is old software. We need to Upgrade this switch, as we check on cisco site have
c2960x-universalk9-mz.152-7.E6.bin
 This New Software can i Upgrade this new Software in the switch.
Is it working properly.
5 Replies 5
yes, you can upgrade to the target version.
suggest reading the release notes: see any caveats which effects your environment :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960l/software/15-2_7_e/release_note/rn-1527e-2960l.html
BB
yes, can upgrade it.
make sure have you checked bugs that do not affect your environment .
here is the process you can follow.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960l/software/15-2_7_e/release_note/rn-1527e-2960l.html#pgfId-301666
https://youtu.be/ryU0wrN7tyk
Jitendra
Thanks.
Thanks for the solution.
