Cisco switch WS-C3560X-48PF-S Smartport GUI problems after upgrade to 15.2
haselldavid
We have a large number of WS-C3560X switches that we recently upgraded to version 15.2.4E7 from 15.0.2E11 and all are exhibiting the same problem of making certain types of Smartport changes via the GUI (although the CLI changes work fine).
It only seems to be an issue when trying to change an interface to a role of "Cisco Switch" or "Cisco Access Point"
This is through the GUI - Configure - Smartports
and basically the change just reverts back to the previous role after clicking on submit.
I've experiment with different browsers/computers and am seeing the same problem.
I've also tried reinstalling the software and confirmed that there are no errors or problems during the log.
(archive download-sw /overwrite /reload tftp://172.16.1.21/c3560e-universalk9-tar.152-4.E7.tar)
Wondering if anyone else is experiencing similar problems or if there may be a solution or simple workaround.
Deepak Kumar
Really, I never worked on GUI. Can you share CLI configuration?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I've left out the
enable secret
and
username lines
SPS75H#show run
Building configuration...
Current configuration : 32745 bytes
! Last configuration change at 19:26:46 UTC Tue Mar 26 2019
! NVRAM config last updated at 19:26:46 UTC Tue Mar 26 2019
version 15.0
no service pad
hostname SPS75H
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip domain-name domain.ca
login block-for 90 attempts 5 within 60
login delay 2
login quiet-mode access-class SSH_MGMT
login on-failure log every 4
udld aggressive
mls qos map policed-dscp 0 10 18 24 46 to 8
mls qos map cos-dscp 0 8 16 24 32 46 46 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
crypto pki trustpoint TP-self-signed-88507904
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-88507904
revocation-check none
rsakeypair TP-self-signed-88507904
crypto pki certificate chain TP-self-signed-88507904
certificate self-signed 02
quit
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree mst configuration
name sps-central
revision 10
instance 1 vlan 100, 900, 1000, 1500
errdisable recovery cause link-flap
errdisable recovery cause l2ptguard
errdisable recovery interval 60
vlan internal allocation policy ascending
ip ssh version 2
lldp run
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
set dscp ef
police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
set dscp cs3
police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
set dscp default
police 10000000 8000 exceed-action policed-dscp-transmit
macro global description cisco-global
interface Port-channel1
switchport trunk native vlan 100
switchport trunk allowed vlan 100,900
switchport mode trunk
interface FastEthernet0
ip address 10.0.1.1 255.255.255.0
no ip mroute-cache
interface GigabitEthernet0/1
description uplink
srr-queue bandwidth share 1 30 35 5
queue-set 2
priority-queue out
ipv6 traffic-filter blockipv6 in
mls qos trust cos
macro description cisco-switch
auto qos trust
spanning-tree link-type point-to-point
interface GigabitEthernet0/2
switchport access vlan 100
switchport mode access
switchport voice vlan 900
switchport port-security maximum 2
switchport port-security violation restrict
switchport port-security aging time 2
switchport port-security aging type inactivity
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
macro description cisco-phone
auto qos voip cisco-phone
spanning-tree bpduguard enable
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
interface GigabitEthernet0/3
queue-set 2
priority-queue out
mls qos trust cos
interface GigabitEthernet0/4
priority-queue out
mls qos trust cos
interface GigabitEthernet0/5
queue-set 2
priority-queue out
mls qos trust cos
interface GigabitEthernet0/6
queue-set 2
priority-queue out
mls qos trust cos
interface GigabitEthernet0/7
queue-set 2
priority-queue out
mls qos trust cos
interface GigabitEthernet0/8
priority-queue out
mls qos trust cos
interface GigabitEthernet0/9
priority-queue out
mls qos trust cos
interface GigabitEthernet0/10
priority-queue out
mls qos trust cos
interface GigabitEthernet0/11
priority-queue out
mls qos trust cos
interface GigabitEthernet0/12
priority-queue out
mls qos trust cos
interface GigabitEthernet0/13
priority-queue out
mls qos trust cos
interface GigabitEthernet0/14
priority-queue out
mls qos trust cos
interface GigabitEthernet0/15
priority-queue out
mls qos trust cos
interface GigabitEthernet0/16
priority-queue out
mls qos trust cos
interface GigabitEthernet0/17
priority-queue out
mls qos trust cos
interface GigabitEthernet0/18
priority-queue out
mls qos trust cos
interface GigabitEthernet0/19
priority-queue out
mls qos trust cos
interface GigabitEthernet0/20
priority-queue out
mls qos trust cos
interface GigabitEthernet0/21
priority-queue out
mls qos trust cos
interface GigabitEthernet0/22
priority-queue out
mls qos trust cos
interface GigabitEthernet0/23
priority-queue out
mls qos trust cos
interface GigabitEthernet0/24
priority-queue out
mls qos trust cos
interface GigabitEthernet0/25
switchport nonegotiate
priority-queue out
mls qos trust cos
macro description cisco-wireless
auto qos trust
interface GigabitEthernet0/26
priority-queue out
mls qos trust cos
interface GigabitEthernet0/27
priority-queue out
mls qos trust cos
interface GigabitEthernet0/28
priority-queue out
mls qos trust cos
interface GigabitEthernet0/29
priority-queue out
mls qos trust cos
interface GigabitEthernet0/30
priority-queue out
mls qos trust cos
interface GigabitEthernet0/31
priority-queue out
mls qos trust cos
interface GigabitEthernet0/32
priority-queue out
mls qos trust cos
interface GigabitEthernet0/33
priority-queue out
mls qos trust cos
interface GigabitEthernet0/34
priority-queue out
mls qos trust cos
interface GigabitEthernet0/35
priority-queue out
mls qos trust cos
interface GigabitEthernet0/36
priority-queue out
mls qos trust cos
interface GigabitEthernet0/37
priority-queue out
mls qos trust cos
interface GigabitEthernet0/38
priority-queue out
mls qos trust cos
auto qos trust
interface GigabitEthernet0/39
priority-queue out
mls qos trust cos
interface GigabitEthernet0/40
priority-queue out
mls qos trust cos
interface GigabitEthernet0/41
priority-queue out
mls qos trust cos
interface GigabitEthernet0/42
priority-queue out
mls qos trust cos
interface GigabitEthernet0/43
priority-queue out
mls qos trust cos
interface GigabitEthernet0/44
priority-queue out
mls qos trust cos
interface GigabitEthernet0/45
priority-queue out
mls qos trust cos
interface GigabitEthernet0/46
priority-queue out
mls qos trust cos
interface GigabitEthernet0/47
priority-queue out
mls qos trust cos
auto qos trust
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet0/48
priority-queue out
mls qos trust cos
auto qos trust
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
no ip address
no ip mroute-cache
interface Vlan100
ip address 172.16.0.75 255.255.128.0
interface Vlan900
no ip address
interface Vlan1500
no ip address
ip default-gateway 172.16.0.254
ip http server
ip http secure-server
ip access-list standard SSH_MGMT
permit 172.16.1.21
permit 172.16.3.15
ip access-list extended AUTOQOS-ACL-DEFAULT
permit ip any any
ip sla enable reaction-alerts
snmp-server location Central Office
snmp-server contact IS
vstack
line con 0
exec-timeout 300 0
login local
line vty 0 4
exec-timeout 300 0
login local
length 0
transport input ssh
line vty 5 15
exec-timeout 300 0
login local
length 0
transport input ssh
ntp server 10.196.128.1 prefer
ntp server 10.196.128.56
end
SPS75H#
