Cisco Switch
dimi.kard
Hi All,
i have a cisco 3560 as you can see on the below config i am unable to access via telnet or ssh, unfortunatelly i do not have console cable, only optio is via http, but default credentials (cisco/cisco or Cisco/Cisco) do not work.
any idea
version 12.2
no service pad
hostname ##hostname##
username admin privilege 15 secret pass
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip dhcp excluded-address 10.50.1.201 10.50.1.254
no file verify auto
spanning-tree mode pvst
spanning-tree uplinkfast
vlan internal allocation policy ascending
interface GigabitEthernet0/1
switchport access vlan 2
switchport voice vlan 7
spanning-tree portfast
interface GigabitEthernet0/2
description Captain_Cabin_Printer
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
description Hyper-V
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
description Uplink_Firewall
interface GigabitEthernet0/17
description NAS
interface GigabitEthernet0/18
description Printer Reserved
interface GigabitEthernet0/19
description PC Reserved
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
description Uplink Firewall
switchport access vlan 5
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
switchport access vlan 4
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
description Cisco Switch
switchport mode trunk
interface GigabitEthernet0/48
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.50.0.2 255.255.255.0
ip classless
ip http server
control-plane
line con 0
password ##pass##
login local
line vty 0 4
login
line vty 5 15
login
end
Mark Elsen
     - Sorry , but you  will need console access to review and or enable ssh/telnet access.
 M.
