Cisco Switchport gets into err-disabled state when connected to a HP switch.
Talha Abbasi
Hello all... I've recently been assigned a task to provide connectivity to a small elementary school.  I'm running into an issue and would appreciate advice/suggestions:
  1. Linksys E2500 router acting as DHCP (and connected to modem provided by Optimum)
  2. Static Public IP assigned to router
  3. Internal LAN scheme is 192.168.1.x
  4. Online connectivity is OK and working fine when directly connected via hardwire to Linksys router (or via wifi)
  5. Ethernet 1 port (on Linksys) connect to Cisco 3550 fa0/24 (switch has basic configuration, no VLANS, all ports are on default VLAN1)
  6. HP switch connected to Cisco 3550 port fa0/23
  7. Netgear switch connected to HP switch port fa0/48
The issue is that when I connect the HP switch with the CIsco swith..... fa0/24 (on Cisco 3550) goes into err-disabled state, and i've to do a shut/no-shut to bring it back up.
I then decided to individually connect all three switches with the Linksys router (and not connect the switches with each other), but encountered the same issue, where port fa0/24 on the Cisco switch shuts down and goes into err-disable state.
Any ideas as to what could be causing this?  Is it BDPU guard acting up?
Thanks for reading.
/regards
mahesh18
Level 6
Level 6
Hi Talha,
Yes seems it is BPDU guard  configured on cisco switch.
You need to disable that if you want it to make work with HP switch
MAhesh
Hi Mahesh,
Please note that all switchports on the Cisco switch do not have any specific configuration assigned to them.  The config is pretty basic/factory default.  Only things configured on the switch are:
  1. static IP assigned to vlan 1
  2. default gateway
  3. enable password
  4. line con 0 password
  5. line vty 0 4 password
  6. vtp mode set to transparent
  7. ...and that is it.
nothing else done on this Cisco switch.
Is the BDPU guard configured automatically on these 3550s?
Regards.
If you look at "show logg | in err " you should be able to see the log entry for the switch port going down. That will give you an idication why port is going to error-disabled
SW# sh logg | in err
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Sep 16 12:44:03 AEST: %PM-4-ERR_DISABLE: bpduguard error detected on Gi1/0/1, putting Gi1/0/1 in err-disable state
Also following command will also help you to troubleshoot
SW#show errdisable recovery
ErrDisable Reason            Timer Status
arp-inspection               Disabled
bpduguard                    Enabled
channel-misconfig (STP)      Enabled
dhcp-rate-limit              Disabled
dtp-flap                     Disabled
gbic-invalid                 Disabled
inline-power                 Disabled
l2ptguard                    Disabled
link-flap                    Enabled
mac-limit                    Disabled
loopback                     Enabled
pagp-flap                    Disabled
port-mode-failure            Disabled
pppoe-ia-rate-limit          Disabled
psecure-violation            Enabled
security-violation           Enabled
sfp-config-mismatch          Disabled
small-frame                  Disabled
storm-control                Enabled
udld                         Enabled
vmps                         Disabled
psp                          Disabled
Timer interval: 60 seconds
Interfaces that will be enabled at the next timeout:
Interface       Errdisable reason       Time left(sec)
Gi1/0/1                bpduguard           40
Rasika
Immediately after the port goes into err-disable, post the output to the command "sh interface status err".
