CISCO TDR Test - PAIR mappings
stedaleo
Thank you to all who have posted and responded to all of the TDR questions over the past which i have reviewed.
I could not find thru many searches any mention of what Cisco PAIR A,B, &  map to...
I would like to know if anyone can confirm the CISCO TDR output Pair A - Pair D mappings to the actual pins of the RJ45. I ask as i do not like assuming that PAIR A is PAIR 1 white/blue & blue/white  pins 4&5 of the connector.
I am hoping there is a table somewhere tahe looks something like this
PAIR A - pins 4/5
PAIR B - pins 1/2
PAIR C - pins 3/6
PAIR D - pins 7/8
will help identify which cable pair is bad in output
Thanks all
Here are test results from working cameras
sh cabl tdr int Gi4/0/39
TDR test last run on: August 26 09:43:27
Interface Speed Local pair Pair length Remote pair Pair status
Gi4/0/39 100M
Pair A 0 +/- 1 meters Pair B Normal
Pair B 0 +/- 1 meters Pair A Normal
Pair C 86 +/- 1 meters N/A Short
Pair D 86 +/- 1 meters N/A Short
Gi3/0/43 100M
Pair C 44 +/- 1 meters N/A Short
Pair D 44 +/- 1 meters N/A Short
This plus my picture above post will have to give us PAIR A - pins 1/2
PAIR B - pins 3/6, right?
7 Replies 7
Martin L
I think it is
PAIR A - pins 1/2
PAIR B - pins 3/6
but let me check .. ....
https://learningnetwork.cisco.com/message/724426#724426
balaji.bandi
Look page 48-50 will have more information :
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2017/pdf/LTRNMS-3602.pdf
BB
Thank you for quick response.
I see the pin assignment for the 568A
As well as the pair a thru d
I did not see that Pair A from the output of the show cable output corresponds to specific pins.
I was hoping to see documented by Cisco that Pair A goes to RJ45 pins 4&5
Thank you again
this is what I see on that pdf shared above
Martin L
My cable tests show Pair A and B are good for cables with IP Cameras via PoE 3750/3850 running at 100 Mbps.  That's why I think pins are
PAIR A - pins 1/2
PAIR B - pins 3/6
source
https://www.cisco.com/c/en/us/td/docs/video/cds/cde/installation/guide/CDE_Install_Book/Connectors.pdf
shows 100Mb and 1000Mb Ethernet pairs.
will add some actual cable tests later
Regards, ML
**Please Rate All Helpful Responses **
Gi4/0/39 100M
Gi3/0/43 100M
