Cisco tool for event and fault management
fabio.marino
Hi to all, i need to suggest to my client some Cisco tool foe "Event and Fault Management".
I knew the the Cisco InfoCenter but i read that is no longer being sold.
Do you know an alternative?
My request are:
1)Must be Cisco brand
2)The network that i need to monitor is composed of about 70 devices (switch, router and catalyst).
Thanks.
Antonio Knox
Level 7
Level 7
5 Replies 5
Antonio Knox
Level 7
Level 7
Look into the Fault Management module in CiscoWorks LMS 4.0 or later.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps11200/deployment_guide_c07-618226.html#wp9001130
Please rate if helpful.
Thanks you got what i'm loking for
Thanks for marking this query as 'Answered', but why a 3 star rating?  Is there more that you require?  I can help further if needed.
Hello Antonio,
this is an error of the rating system:
current CSC provides 5 points for an answer flagged as solving the issue
but some times you can get a solved with 0 points, or in this case with 3 points
I'm afraid It is part of the game
you are doing good here in the forums
Hope to help
Giuseppe
Oh, okay.  I didn't know that. Same thing happened last week, but I got an answered and got 0 stars for it.  I'm relieved to know it's just a bug.  I thought there was something wrong with the solutions I offered.
