Cisco VSS wih diferent Chassis Types
patcbr600
Hi all,
Can any one tell me if its possible to have two diferente chassis type from Cisco Catalyst 6500 to form a VSS system
Exemple:
Cisco Catalyst 6509-NEB-A   and Cisco Catalyst 6513-E, with the same VS-SUP and modules.
IAN WHITMORE
Level 4
Level 4
Q. How many Cisco Catalyst 6500 Series Switches can be part of a VSS?
A. The VSS1440 will allow up to two physical Cisco Catalyst 6500 Series Switches to operate as a VSS. The two physical chassis does not need to be identical in the type of modules installed or even type of chassis. For example, a WS-C6503-E chassis can be combined with a WS-C6513 chassis to form a VSS.
Reference:
HTH,
Ian
