CISCO WS-6509-E and WS-CAC-6000W
masterxp25
Hello community,
We has a 6509-E with the following modules:
  • 1x WS-CAC-6000W
  • 1x WS-SUP720-3BXL
  • 1x WS-X6748-GE-TX
I test the Power Supply with two 110v and with two 220v lines, but i only receiving 807.24 Watts from the Power Supply.
I see very stranger that in the output of the Show Power command, this doesn't show the Power Supply model, it said "none".
The documentation of WS-CAC-6000W saids that i need IOS 12.2(18)SXD and later, and i has 12.2(18)SXD7b.
This is the output of SHOW POWER:
Router#show power
system power redundancy mode = redundant
system power redundancy operationally = non-redundant
system power total =     0 Watt
system power used =       807.24 Watts (19.22 Amps @ 42V)
system power available =  807.24 Watts (19.22 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    none
2    none
                                       Pwr-Allocated  Oper
Fan  Type                         Watts      A @42V      State
1    WS-C6509-E-FAN   150.36      3.58               OK
                              Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
3    WS-X6748-GE-TX      407.40  9.70     -     -     on    off (FRU-power denied)
5    WS-SUP720-3BXL      328.44  7.82   328.44  7.82  on    on
6    (Redundant Sup)       -     -      328.44  7.82  -     -
Any help will be appreciate.
Thanks beforehand.
Reza Sharifi
It maybe a bug in the version of IOS you are running.  Upgrade to a newer version and test again.
Hi Reza,
Thanks for answer.
I test too with 15.1(1)SY, and get the  same results.
Another idea?
