09-18-2018 06:40 AM - edited 03-08-2019 04:11 PM
i have a cisco WS-C2960C-8PC-L , but it doesnt work fine. it has 8 ports but just only four work correctly,
when we connect any cable into any port, it just work when we do it in the last four port.
the first four ports doent get up the link or even PoE
PLEASE, could you give me some light on this issue ¿?¿
catalyst#show power inline
Available:124.0(w) Used:18.0(w) Remaining:106.0(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/5 auto on 6.0 IP Phone 6921 2 15.4
Fa0/6 auto on 6.0 IP Phone 6921 0 15.4
Fa0/7 auto on 6.0 IP Phone 6921 2 15.4
Fa0/8 auto off 0.0 n/a n/a 15.4
catalyst#sh ip int brie
Vlan1 10.56.56.91 YES manual up up
FastEthernet0/1 unassigned YES unset down down
FastEthernet0/2 unassigned YES unset down down
FastEthernet0/3 unassigned YES unset down down
FastEthernet0/4 unassigned YES unset down down
Solved! Go to Solution.
09-18-2018 11:03 PM
As you can see from the test the PoE for the first 4 ports have some problems:
POST: Inline Power Controller Tests : Begin
POST: inline power post failed for port 0
POST: inline power post failed for port 1
POST: inline power post failed for port 2
POST: inline power post failed for port 3
POST: Inline Power Controller Tests : End, Status Failed
As suggested from Mr. Leo Laohoo you can ask for an RMA.
Regards.
09-18-2018 06:50 AM
Hi, do you have errors in the boot logs?
Can you execute a diagnostic test to check the ports status?
Regards.
09-18-2018 01:21 PM
these are the results of the dianostico test command
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
please help for this, or maybe i should raise a request for RMA ?
regards
09-18-2018 02:21 PM
PoE module is dead. Please organize for an RMA.
09-18-2018 11:03 PM
Regards.
