Bookmark
Subscribe
2856
Cisco WS-C2960CX-8PC-L wired dot1x problem
Denis Orlov
Hi.
We purchased WS-C2960CX-8PC-L switches and begin to deploy them in our infrastructure.
In our enterprise network we using dot1x with mab.
We have following IOS on WS-C2960CX-8PC-L:
Cisco IOS Software, C2960CX Software (C2960CX-UNIVERSALK9-M), Version 15.2(6)E1, RELEASE SOFTWARE (fc4)
Our dot1x settings are the following:
aaa new-model
aaa group server radius net-auth
 server name dl-dc01
aaa authentication dot1x default group radius
aaa authorization network default group radius
mab request format attribute 2 7 ################
dot1x system-auth-control
dot1x logging verbose
service-template default_dot1x_vlan
 vlan 40
policy-map type control subscriber dot1x_policy
 event session-started match-all
  10 class always do-all
   10 authenticate using dot1x priority 10
   20 authenticate using mab priority 20
 event authentication-failure match-all
   10 activate service-template default_dot1x_vlan
interface GigabitEthernet0/1
 switchport mode access
 switchport voice vlan 100
 access-session host-mode single-host
 access-session port-control auto
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 5
 dot1x max-reauth-req 3
 spanning-tree portfast edge
 spanning-tree bpdufilter enable
 service-policy type control subscriber dot1x_policy
When we connect PC to interface Gi 0/1 we always get PC into vlan 40.
But we see dot1x mab request on our radius server and also we see that our radius server respond with access-accept message (we using MS NPS as Radius server).
But in "debug radius" we see the following:
Jul  9 12:24:19.573: RADIUS/ENCODE(00000000):Orig. component type = Invalid
Jul  9 12:24:19.573: RADIUS(00000000): Config NAS IP: 10.10.30.83
Jul  9 12:24:19.573: RADIUS(00000000): Config NAS IPv6: ::
Jul  9 12:24:19.573: RADIUS(00000000): sending
Jul  9 12:24:19.573: RADIUS: Message Authenticator encoded
Jul  9 12:24:19.573: RADIUS(00000000): Send Access-Request to 10.10.49.10:1645 onvrf(0) id 1645/7, len 264
Jul  9 12:24:19.573: RADIUS:  authenticator 95 BB 73 3C 38 18 B6 19 - 08 89 FF 11 64 47 73 B3
Jul  9 12:24:19.577: RADIUS:  User-Name           [1]   14  "847beb27d595"
Jul  9 12:24:19.577: RADIUS:  User-Password       [2]   18  *
Jul  9 12:24:19.577: RADIUS:  Service-Type        [6]   6   Call Check                [10]
Jul  9 12:24:19.577: RADIUS:  Vendor, Cisco       [26]  31
Jul  9 12:24:19.577: RADIUS:   Cisco AVpair       [1]   25  "service-type=Call Check"
Jul  9 12:24:19.577: RADIUS:  Framed-MTU          [12]  6   1500
Jul  9 12:24:19.577: RADIUS:  Called-Station-Id   [30]  19  "00-45-1D-E8-26-01"
Jul  9 12:24:19.577: RADIUS:  Calling-Station-Id  [31]  19  "84-7B-EB-27-D5-95"
Jul  9 12:24:19.577: RADIUS:  Message-Authenticato[80]  18
Jul  9 12:24:19.577: RADIUS:   41 20 9B 4F FB AB B6 C0 4F 82 D8 8B 2A 5C A9 F5            [ A OO*\]
Jul  9 12:24:19.577: RADIUS:  EAP-Key-Name        [102] 2   *
Jul  9 12:24:19.577: RADIUS:  Vendor, Cisco       [26]  49
Jul  9 12:24:19.577: RADIUS:   Cisco AVpair       [1]   43  "audit-session-id=0A0A1E53000000130017995E"
Jul  9 12:24:19.577: RADIUS:  Vendor, Cisco       [26]  18
Jul  9 12:24:19.577: RADIUS:   Cisco AVpair       [1]   12  "method=mab"
Jul  9 12:24:19.577: RADIUS:  Framed-IP-Address   [8]   6   169.254.103.147
Jul  9 12:24:19.577: RADIUS:  NAS-IP-Address      [4]   6   10.10.30.83
Jul  9 12:24:19.577: RADIUS:  NAS-Port-Id         [87]  20  "GigabitEthernet0/1"
Jul  9 12:24:19.577: RADIUS:  NAS-Port-Type       [61]  6   Ethernet                  [15]
Jul  9 12:24:19.577: RADIUS:  NAS-Port            [5]   6   50101
Jul  9 12:24:19.577: RADIUS(00000000): Sending a IPv4 Radius Packet
Jul  9 12:24:19.577: RADIUS(00000000): Started 5 sec timeout
Jul  9 12:24:19.587: RADIUS: Received from id 1645/7 10.10.49.10:1645, Access-Accept, len 100
Jul  9 12:24:19.587: RADIUS:  authenticator 46 9B DF 85 3C 16 8C 32 - 15 87 31 88 EC 7E 05 2B
Jul  9 12:24:19.587: RADIUS:  Vendor, Cisco       [26]  6
Jul  9 12:24:19.587: RADIUS:  Framed-Protocol     [7]   6   PPP                       [1]
Jul  9 12:24:19.587: RADIUS:  Service-Type        [6]   6   Framed                    [2]
Jul  9 12:24:19.587: RADIUS:  Tunnel-Medium-Type  [65]  6   00:ALL_802                [6]
Jul  9 12:24:19.587: RADIUS:  Tunnel-Private-Group[81]  4   "15"
Jul  9 12:24:19.587: RADIUS:  Tunnel-Type         [64]  6   00:VLAN                   [13]
Jul  9 12:24:19.587: RADIUS:  Class               [25]  46
Jul  9 12:24:19.587: RADIUS:   97 16 09 F4 00 00 01 37 00 01 02 00 0A 0A 31 0A 00 00 00 00 15 D1 79 35 49 F2 51 B3 01 D3 F3 2E 41 C2 BD E3 00 00 00 00 00 04 89 71         [ 71y5IQ.Aq]
Jul  9 12:24:19.587: RADIUS(00000000): Received from id 1645/7
Jul  9 12:24:19.587: RADIUS/DECODE: VSA external len != internal + VSA hdr
Jul  9 12:24:19.587: RADIUS/DECODE: decoder; FAIL
Jul  9 12:24:19.587: RADIUS/DECODE: attribute Vendor-Specific; FAIL
Jul  9 12:24:19.587: RADIUS/DECODE: parse response op decode; FAIL
The same configuration of dot1x we successfully using on our 2960x, 3650.
How can we achieve normal vlan assignment by radius server?
Can somebody help with this situation?
Denis Orlov
The problem was successfuly resolved.
We removed Vendor Specific attribute in NPS network policy settings on "Settings" Tab.
See screenshot
Denis Orlov
See screenshot
