Cisco WS-C2960X-24PS-L | Upgrade path from 15.0(2a)EX5 to 15.2(7)E7
ArjunRajeev
I'm planning to upgrade my Cisco WS-C2960X-24PS-L switch from its current software version of 15.0(2a)EX5 to the Cisco-recommended version of 15.2(7)E7. Can I perform the upgrade in one step, or is there a specific upgrade path that I need to follow?
5 Replies 5
Leo Laohoo
Direct upgrade is supported.
Cold-reboot (pull the power cable) is mandatory.
Follow up question on this: Is the cold-reboot needed for upgrading through GUI?
For any other switches, not necessarily.  For the 2960X, I would recommend a cold reboot.
@Leo Laohoo  Can you tell us please why would you recommend a cold reboot for this model ?
Appreciate your feedabck.
Thx
There is micro-code bug present in 2960X that are on EX3 (and earlier) --  CSCvf24186
If the switch has never had the IOS upgrade, cold reboot.
