cisco WS-C3550-24-PWR upgrade
eMediaVillage
I would really like to upgrade this switch before a reinstall it.. The software is quite old.. based on the current IOS installed, can someone point to the best version/package to download for this switch.
Thanks in advance
cisco WS-C3550-24-PWR (PowerPC) processor (revision D0) with 65526K/8192K bytes
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(13)EA1a, RELEASE SOFTWARE
Flash :15998976 bytes total (10727936 bytes free)
glen.grant
   The last version they released before this model went End of Maintenance  was  c3550-ipbasek9-mz.122-44.SE6.bin .
5 Replies 5
eMediaVillage
FYI - the following may be relevent to an accurate answer to my question
thanks again
Motherboard assembly number: 73-8100-07
Power supply part number: 341-0029-02
Motherboard serial number: CAT072202Q4
Power supply serial number: DTH07190VE8
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number: CAT0722R0VH
Configuration register is 0x10F
glen.grant
Thanks, that helps.
Based on what is currently installed on my switch C3550-I9Q3L2-M what package needs,  can be, or is the best to installed?
I am not sure what I9Q3L2-M means?
c3550-ipbase-mz.122-44.SE6.bin IP BASE W/O CRYPTO
c3550-ipbase-tar.122-44.SE6.tar IP BASE W/O CRYPTO WITH WEB BASED DEV MGR
c3550-ipbasek9-mz.122-44.SE6.bin IP BASE
c3550-ipbasek9-tar.122-44.SE6.tar IP BASE WITH WEB BASED DEV MGR
c3550-ipservices-mz.122-44.SE6.bin IP SERVICES W/O CRYPTO
c3550-ipservices-tar.122-44.SE6.tar IP SERVICES W/O CRYPTO WITH WEB BASED DEV MGR
c3550-ipservicesk9-mz.122-44.SE6.bin IP SERVICES
c3550-ipservicesk9-tar.122-44.SE6.tar IP SERVICES WITH WEB BASED DEV MGR
I think i figured out that i need to use the following because my switch is SMI
  That is correct , because your switch is SMI that means you  would run the base code.  Unless you plan on running the gui interface you do not need the .tar file just use the .bin .
