cisco ws-c3750g-24ps-s bootloader problem
surekha.sharma
HI,
Swich model is ws-c3750g-24ps-s but it is showing WS-C3750G-24WS-S25/50 and while booting it is like this
not as usual :
i belive this is bootloader issue i tried to upgrade the ios but that does not work it is still showing
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M), Version 12.2 [tting-dsbu2 148]
how i can change this bootloader due to this it is also not going to rommon mode.
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(52)SE, R
ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:32 by sasyamal
Image text-base: 0x01000000, data-base: 0x02E00000
ROM: Bootstrap program is C3750 boot loader
Switch uptime is 1 hour, 0 minutes
System image file is "flash:/c3750-ipservicesk9-mz.122-52.SE/c3750-ipservicesk9-
mz.122-52.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24WS-S25/50 (PowerPC405) processor (revision C0) with 131072K by
tes of memory.
Processor board ID FOCXXXXXXX
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:15:F9:CE:09:00
Motherboard assembly number     : 73-9357-08
Power supply part number        : 341-0108-02
Motherboard serial number       : FOCXXXXXXX
Power supply serial number      : DCXXXXXXXX
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24PS-S
System serial number            : FOCXXXXXXX
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CATXXXXXXXX
Top Assembly Part Number        : 800-25429-02
Top Assembly Revision Number    : B0
Version ID                      : V02
CLEI Code Number                : CNMWR00ARB
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24WS-S25 12.2(52)SE            C3750-IPSERVICESK9-M
Configuration register is 0xF
Switch#
Reza Sharifi
You are already running IOS version 122-52.SE
mz.122-52.SE.bin"
What are you trying to change it to?
Reza
5 Replies 5
Reza Sharifi
mz.122-52.SE.bin"
Reza
I need to change bootloader , ios is not a problem
Firstly, when you upgrade the IOS to 12.2(50) and later, the IOS will upgrade the bootloader.
Secondly, the WS-C3750G-24WS-S25 is a WS-C3750G-24-PS with a WLC built on top of it.
Can you please explain what is your problem?
the bootloader was not upgraded even though we installed latest image , due to this bootloader we not able to into rommon mode just see my attchment .
glen.grant
  So whats the actual issue just that the model number appears wrong ?   The bootloader does not get upgraded with every single version upgrade .  If the display bothers you try a different version  and see if that clears the issue otherwise contact the TAC it may be a cosmetic issue with the code where it is showing the wrong model number.  Also verify you have the model you think it is , usually on a sticker on the back of the switch.
