12-23-2008 03:50 AM - edited 03-06-2019 03:06 AM
I am new to all this so please bear with me.
I have a WS-C3750G-24S-E switch and am using it to setup port based VLANs.
I want to connect seperate switches to each VLAN port so that I can put several PCs connected to the local switch then connect the local switch to the VLAN port on the C3750
I have tried this with a layer 2 netgear switch but this does not work.
My question is what switch do I need for this scenario? We cannot afford to spend lots of money on this and I assumed any layer 2 switch would work.
12-23-2008 04:08 AM
There is no reason that should not work if set up correctly . On the 3750 you would create the layer 2 vlan and then the corresponding layer 3 SVI . Assign the ports that you want to connect to the other switches into the vlans you want on the other switches assuming that it is just a basic unmanaged switch would then be in that vlan . Example below.This will put a port to a switch into vlan 3 and would be a routable vlan . You would then do the same for the other vlans you want to create.
3750>
conf t
vtp mode transparent
vlan 3
name 192.168.3.0/24
exit
int vlan 3
ip address 192.168.3.1 255.255.255.0
no shut
exit
conf t
int g1/0/1
description port to unmanaged netgear switch
switchport
switchport mode access
switchport access vlan 3
12-23-2008 05:27 AM
Thanks for this I will check it out
