Cisco WS-C3850-24S-P ABNORMAL
Hazem.hussain
I Have this Cisco Switch model : WS-C3850-24S-P
when i turn on the switch and connect to switch via console cable
the switch try to boat and than give this error
ABNORMAL_RESET_COUNT=0
and all light's keeps on ,, i have tried to reset using button but it's the same
2 Accepted Solutions
on a side note, it looks like all your LEDs are amber, meaning all LEDs signal a fault ? It could very well be that your device is toast, and you need to return it...
I may be thinking if you done that steps very carefully, then time to raise an ticket with TAC for RMA. (if you have contract)
BB
8 Replies 8
balaji.bandi
Turn off the device and wait for 1 or 2min and  follow emergency recovery :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html#anc20
BB
Hazem.hussain
Hello, @balaji.bandi thank you for your help I have
tried to turn off the switch for 10 minutes
and I turn it on again it's showing the same issue loop booting, also I have tried The Mode button when the switch boot up but - it's the same
please see attached video of booting
it should work - we have done many. (step 4 is very important )
SUMMARY STEPS
1.    Connect a terminal or PC to the switch.
2.    Set the line speed on the emulation software to 9600 baud.( Configure the PC or laptop terminal emulation software for 9600 baud, 8 data bits, no parity, 1 stop bit, and no flow control.)
3.    Power off the switch.
4.    Reconnect the power cord to the or the active switch. Within 15 seconds, press the Mode button while the System LED is still flashing green. Continue pressing the Mode button until all the system LEDs turn on and remain solid; then release the Mode button.
BB
Hazem.hussain
@balaji.bandi thank you i have done those steps very carefully but there is nothing it's the same issue
loop boot as the video i have post before
@Georg Pauwen @balaji.bandi
please see the video of the light's all of them on all the time no blinking
BB
@balaji.bandi if i don't have a contract with them then what
and is it possible to fix this issue only using software or it's hardware issue and they have to fix it not me
balaji.bandi
You need to have contract for cisco to replace. (cisco come with only 90days warranty)
BB
