08-10-2021 07:02 AM
Hi have a cliente with a Cisco Catalyst 4500 L3 (cisco WS-C4510R-E), it has dual 10gb ports per module, but i can only activate one 10gb port per module, it says its inactive (Te5/2 and Te6/2):
switch#show int status mod 5
Port Name Status Vlan Duplex Speed Type
Te5/1 ------------ connected trunk full 10G 10GBase-SR
Te5/2 ------------ inactive 1 full 10G 10GBase-ER
Gi5/3 ------------ inactive 1 full 1000 No Gbic
Gi5/4 ------------ inactive 1 full 1000 No Gbic
Gi5/5 inactive routed full 1000 No Gbic
Gi5/6 inactive routed full 1000 No Gbic
switch#show int status mod 6
Te6/1 ------------ connected trunk full 10G 10GBase-SR
Te6/2 ------------ inactive 1 full 10G 10GBase-ER
Gi6/3 ------------ inactive 1 full 1000 No Gbic
Gi6/4 ------------ inactive 1 full 1000 No Gbic
Gi6/5 inactive routed full 1000 No Gbic
Gi6/6 inactive routed full 1000 No Gbic
I have tried to do the commands:
switch(config)#hw-module module 5 port-group 2 select tengigabitethernet
switch(config)#hw-module module 6 port-group 2 select tengigabitethernet
Still appears has inactive.
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 12.2(50)SG2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 27-Apr-09 18:36 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x126636CC
ROM: 12.2(44r)SG5
Darkside Revision 4, Jawa Revision 20, Tatooine Revision 140, Forerunner Revision 1.74
sw01-core-lis-sc uptime is 10 weeks, 6 days, 19 hours, 32 minutes
Uptime for this control processor is 10 weeks, 6 days, 19 hours, 19 minutes
System restarted at 19:28:40 UTC Tue May 25 2021
System image file is "bootflash:cat4500e-entservicesk9-mz.122-50.SG2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4510R-E (MPC8548) processor (revision 6) with 524288K bytes of memory.
Processor board ID SPE134400RD
MPC8548 CPU at 1.33GHz, Supervisor 6-E
Last reset from PowerUp
10 Virtual Ethernet interfaces
164 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Anyone knows how to activate that ports?
Thanks in advance.
08-10-2021 07:12 AM - edited 08-10-2021 07:18 AM
you possibly refer tot the interfaces on the supervisor module ?
post output from show inventory
only the last column reports switching capacity over 10Gbps,
the other supervisor models do not have the switching capacity for 2x 10G
able 1. Cisco Catalyst 4500 Enhanced Layer 3 Supervisor Engine Performance and Scalability Features
08-10-2021 07:18 AM
sw01-core-lis-sc#show inventory
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4510R-E 10 slot switch "
PID: WS-C4510R-E , VID: V01 , SN: SPE134400RD
NAME: "Clock Module", DESCR: "Clock Module"
PID: WS-X4K-CLOCK-E , VID: V01 , SN: JAE1345NCNJ
NAME: "Mux Buffer 1 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: JAE1334HI8E
NAME: "Mux Buffer 2 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: JAE1334HD2C
NAME: "Mux Buffer 3 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: JAE1334HH5B
NAME: "Mux Buffer 4 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: JAE1334HD7L
NAME: "Mux Buffer 7 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: JAE1334HDB5
NAME: "Mux Buffer 8 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: JAE1334HD2M
NAME: "Mux Buffer 9 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: JAE1334HDCM
NAME: "Mux Buffer 10 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: JAE1334HD7K
NAME: "Linecard(slot 1)", DESCR: "6 Dual media SFP or 10/100/1000BaseT (RJ45)V voice power ports (Cisco/IEEE)"
PID: WS-X4506-GB-T , VID: V06 , SN: JAE1334H2BD
NAME: "GigabitEthernet1/1", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000G
NAME: "GigabitEthernet1/2", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000Z
NAME: "GigabitEthernet1/3", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS13460007
NAME: "GigabitEthernet1/4", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000B
NAME: "GigabitEthernet1/5", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000R
NAME: "GigabitEthernet1/6", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000V
NAME: "Linecard(slot 2)", DESCR: "6 Dual media SFP or 10/100/1000BaseT (RJ45)V voice power ports (Cisco/IEEE)"
PID: WS-X4506-GB-T , VID: V06 , SN: JAE1343M8MI
NAME: "GigabitEthernet2/1", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000S
NAME: "GigabitEthernet2/2", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000L
NAME: "GigabitEthernet2/3", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000M
NAME: "GigabitEthernet2/4", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000W
NAME: "GigabitEthernet2/5", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1346000Y
NAME: "GigabitEthernet2/6", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS13460010
NAME: "Linecard(slot 3)", DESCR: "10/100/1000BaseT (RJ45)V E Series with 48 10/100/1000 baseT PoE ports (Cisco/IE"
PID: WS-X4648-RJ45V-E , VID: V03 , SN: JAE1347OAJR
NAME: "Linecard(slot 4)", DESCR: "10/100/1000BaseT (RJ45)V E Series with 48 10/100/1000 baseT PoE ports (Cisco/IE"
PID: WS-X4648-RJ45V-E , VID: V03 , SN: JAE1347OA56
NAME: "Linecard(slot 5)", DESCR: "Supervisor 6-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports"
PID: WS-X45-SUP6-E , VID: V05 , SN: JAE1342L94B
NAME: "TenGigabitEthernet5/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR , VID: V03 , SN: ONT121801X5
NAME: "TenGigabitEthernet5/2", DESCR: "10Gbase-ER"
PID: X2-10GB-ER , VID: V04 , SN: OPB15140077
NAME: "Linecard(slot 6)", DESCR: "Supervisor 6-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports"
PID: WS-X45-SUP6-E , VID: V05 , SN: JAE1345NPIC
NAME: "TenGigabitEthernet6/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR , VID: V03 , SN: ONT121801TF
NAME: "TenGigabitEthernet6/2", DESCR: "10Gbase-ER"
PID: X2-10GB-ER , VID: V04 , SN: OPB15220445
NAME: "Linecard(slot 7)", DESCR: "10/100/1000BaseT (RJ45)V E Series with 48 10/100/1000 baseT PoE ports (Cisco/IE"
PID: WS-X4648-RJ45V-E , VID: V04 , SN: JAE14490QXA
NAME: "Fan", DESCR: "FanTray"
PID: WS-X4582-E , VID: V02 , SN: SPE134400HR
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 2800W )"
PID: PWR-C45-2800ACV , VID: V05 , SN: SNI1345A357
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 2800W )"
PID: PWR-C45-2800ACV , VID: V05 , SN: SNI1345A35K
08-10-2021 07:19 AM
And thanks
08-10-2021 07:15 AM
what supervisor ?
Look at the below thread - do you think you have same setup :
https://community.cisco.com/t5/switching/4507r-e-ports-inactive/td-p/1758729
08-10-2021 11:04 AM
I don't recall the particulars for your sup6-E, but I do recall (?), on many of the 4500 sups, when running with dual sups you cannot use all of both sups' uplink ports. (I also recall [??], perhaps one of a 4500's sups offered a configuration option to activate all uplink ports on both sups.)
08-10-2021 11:43 AM
Why is the config register 0x2101? It should be 0x2102.
Also, are the sups configure in SSO mode? Can you post the output of "show redundancy"?
08-10-2021 03:28 PM
Wow. That is a very old IOS.
