07-19-2021 09:03 AM
Hi All
Migrating a existing stack of 4 Cisco 3750 to Cisco 9300
Configuration should be copy line by line , copying vlan.dat...
Or there is any tool to check and copy the config?
Solved! Go to Solution.
07-27-2021 05:01 PM
07-19-2021 09:14 AM
- You may find this thread useful :
M.
07-19-2021 04:26 PM
07-27-2021 02:51 PM
Hi all
config copied from Cisco 3750 to tftp server.
Config copied from tftp to cisco 9300..
ok
How about licensing
ionly have mgmt vlans and vlans for clients and printers.
Switch is not connected to the internet..
we nned to route traffic on some vlan to internet?
is that?
07-27-2021 03:19 PM
License will depend entirely on the IOS-XE version the switch (or stack) is running on.
The Cisco Smart License (CSL) supports starts from 16.9.1 up to 17.3.1.
Check the Release Notes, if all switches in the stack can run 16.6.X, then download the latest version of this train.
07-27-2021 03:25 PM - edited 07-27-2021 03:28 PM
we are running 16.12 and we have smart license and dna to install.
switch does not have access to the internet.
as I read, its needed for the licenses to be authorized /validated
how can it be accomplished ? add a vlan with capability to go the internet?
regards
07-27-2021 03:43 PM
07-27-2021 04:35 PM
I will upgrade from 16.12 to 17.3.3
copy tftp: flash:
dir flash:*bin
conf t – boot system flash:packages.conf
wr mem
sh boot system
install add file flash:cat9k_iosxe.17.03.03.SPA.bin activate commit
sh version
correct?
07-27-2021 05:01 PM
07-28-2021 07:09 AM
Leo
thanks worked fine
i also copied the config and create all the vlans.
But i am not able to ping the switch IP from my network.
In older cisco 3850 stack i was..
In the 9300 i can ping al other stacks in vlan of mgmt but when i connect to my network I can't.
vlan 100 is the vlan of all Cisco switches mgmt IP's.
from vlan 90 , per example, i should be to ping the cisco 9300 stack
07-28-2021 07:48 AM
missing ip default gateway ;(
thanks case closed
08-10-2021 02:29 PM
Leo
Is there anything to do after the installation, regarding . Licenses seems ok , but is there any need to send anything for cisco to validate?
i only see this line in config..
license boot level network-essentials addon dna-essentials
08-10-2021 03:42 PM
I am not concerned at this command.
At the end of the license period nothing happens -- There is no "enforcement" action.
