cisco WS-C6509-E (M8572)
mksadmin
i would like to add one more module that should have tengig ports , so here i would like to know whether its possible to add it in switch that i have in my environment.
here are few detail of switch that is in my environment.
#show version
Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.2(1)SY0a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Sun 29-Mar-15 12:51 by prod_rel_team
ROM: System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
s1-lnsmksptc uptime is 2 years, 13 weeks, 2 days, 11 hours, 10 minutes
Uptime for this control processor is 2 years, 13 weeks, 2 days, 10 hours, 56 minutes
System returned to ROM by reload at 00:17:45 UTC Sun Dec 13 2015
System restarted at 18:23:10 CST Sat Dec 12 2015
System image file is "bootdisk:s2t54-ipservicesk9-mz.SPA.152-1.SY0a.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (M8572) processor (revision ) with 1785856K/262144K bytes of memory.
Processor board ID SMG1916N012
CPU: MPC8572_E, Version: 2.2, (0x80E80022)
CORE: E500, Version: 3.0, (0x80210030)
CPU:1500MHz, CCB:600MHz, DDR:600MHz
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from s/w reset
22 Virtual Ethernet interfaces
195 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
2543K bytes of non-volatile configuration memory.
s1-lnsmksptc#show module
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6848-GE-TX SAL1916DJRW
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6848-GE-TX SAL1916DJSB
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6848-GE-TX SAL1915D9CX
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6848-GE-TX SAL1915D9BM
5 5 Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G SAL1914CU9H
Mod MAC addresses Hw Fw Sw Status
1 64f6.9d6e.0020 to 64f6.9d6e.004f 1.4 12.2(18r)S1 15.2(1)SY0a Ok
2 64f6.9d6d.fe40 to 64f6.9d6d.fe6f 1.4 12.2(18r)S1 15.2(1)SY0a Ok
3 64f6.9d6d.eb4c to 64f6.9d6d.eb7b 1.4 12.2(18r)S1 15.2(1)SY0a Ok
4 64f6.9d6d.eb7c to 64f6.9d6d.ebab 1.4 12.2(18r)S1 15.2(1)SY0a Ok
5 7c0e.cedf.a6e7 to 7c0e.cedf.a6ee 2.1 12.2(50r)SYS 15.2(1)SY0a Ok
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6K-DFC4-A SAL1916DJRW 1.4 Ok
2 Distributed Forwarding Card WS-F6K-DFC4-A SAL1916DJSB 1.4 Ok
3 Distributed Forwarding Card WS-F6K-DFC4-A SAL1915D9CX 1.4 Ok
4 Distributed Forwarding Card WS-F6K-DFC4-A SAL1915D9BM 1.4 Ok
5 Policy Feature Card 4 VS-F6K-PFC4 SAL1913CKKJ 3.0 Ok
5 CPU Daughterboard VS-F6K-MSFC5 SAL1914CTX9 3.0 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
6 Replies 6
You have multiple options for 10gig ports module, depends on your requirement. Either copper or Fiber
Your switch is 6509-E, currently 5 slots are used.You can put module in 6,7 ,8 and 9 slots. However 5 and 6 slots are recomended for Sup-Engine.
Below is the link which guide you regarding your requirement
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet09186a00801dce34.html
Note: Some of the part numbers are EOL or EOS. Please confirm before ordering.
Cisco Catalyst 6500 16-Port 10 Gigabit Ethernet Copper Module
Part Number : WS-X6816-10T-2T
Cisco Catalyst 6500 16-Port 10 Gigabit Ethernet Fiber Module
Part Number : SFP-10G-LRM
Spooster IT Services Team
EduardR
It seems it is possible: https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet09186a00801dce34.html, says that "modules are interoperable with the Cisco Catalyst 6500 Series Virtual Switching Supervisor Engine 720 with 10GE uplinks and the Cisco Catalyst 6500 Series Supervisor Engine 720", and in your info it says you have CEF720.
However, you must contact your sales representative and ask him about module compatibility before buying anything
Joseph W. Doherty
Yes you can. You need to insure the 10g card works in a 6500-E chassis. For a sup2T, the 10g card needs a CFC or DFC4, and be supported by your IOS version. (The latter is likely true with your IOS version.)
One 10g card that cannot be used would be the 6708 as it has a DFC3 which cannot be upgraded.
Keep in mind, the 6509-E, is only 80 GBps per slot, so if you have more than eight 10g ports, the card will be oversubscribed. (If you later move your sup2T to a 6807, your maximum slot bandwidth will be increased.)
suleymankutlu
We have a Cisco WS-C6509-E product.We want to use GUI for Cisco WS-C6509-E on Windows 10 Enteprise OS.
Which program can we use?.Can you send us the GUI EXE link?.
Thanks,Regards ...
NOTE:Cisco Network Assistan GUI can not work.Is Cisco Prime LAN Management Solution (LMS) true program?...
Suleyman
Firstly, for your question, I would suggest you post it as a totally new stand alone post, especially rather than a reply to a five year old thread not specific to your issue.
Secondly, as 6500s used to be top tier Enterprise L3 switches, a GUI might be unavailable as such devices were often configured by more knowledgeable network engineers (who are comfortable using the CLI).
