Cisco
sdonnelly_tgg
OK so I'm not sure if I am going down the right path, but I figured I'd post this here.
I have a location running Cisco 7960-62 model phones, all connecting back to a Cisco 2960S ( WS-C2960S-24PS-L   12.2(55)SE3           C2960S-UNIVERSALK9-M).
On gi1/0/21 I have a Cisco 7960 that works fine, but the location is looking to play musical chairs. In this case if I move a 7960, 61, 62 none of those phones will power on. I plug the original phone back in, and it works just fine. I go directly from the phone > switchport and it powers on without an issue (the one I need to move).
I see these errors in the log
Apr 29 13:44:59: %ILPOWER-7-DETECT: Interface Gi1/0/21: Power Device detected: Cisco PD
Apr 29 13:44:59: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/21: PD removed
Here's the config on that port, which mirrors every other port for end-user devices. What am I missing?
interface GigabitEthernet1/0/21
 description --- LAN PORT ---
 switchport mode access
 power inline static
 srr-queue bandwidth share 10 10 60 20
 queue-set 2
 priority-queue out
 mls qos trust device cisco-phone
 mls qos trust cos
 auto qos voip cisco-phone
 spanning-tree portfast
 service-policy input AutoQoS-Police-CiscoPhone
end
acampbell
Can you try this command and retest
power inline auto
Alex
Regards, Alex. Please rate useful posts.
Yes, I will try this out tomorrow morning when the user is not connected. Then I will have them swap phones and see what happens. I will report back then! Thank you.
pwwiddicombe
Level 4
Level 4
Are  you saying the phone, if plugged DIRECTLY into the switch, will work on that port, but not at the workstation?  If so, there may be a cabling issue.  Some of the Gig-capable phones will require all 8 pins; and possibly the older phone may NOT be gig-capable, so it isn't an issue.
If this IS the case, get the cabling corrected; or if 100 Meg is OK, some switches will accept "speed auto 10 100" to limit negotiation to 100 Meg (and only needing the standard 4 pins, not all 8).
Yes that is correct, but if I put the original phone back to the desk and go into the data port that phone powers on and registers for me. All other phones I have tried fail to power on and produce that error I posted above.
All of our phones are 10/100.
