cisco2911/k9 15.5(1)T2 not supporting EIGRP?
yeopaul
Hi guys,
I cant configure EIGRP on this router, is this version supporting EIGRP?
Thanks a lot.
IGW01#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version , RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 27-May-15 04:14 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
IGW01 uptime is 1 week, 2 hours, 26 minutes
System returned to ROM by reload at 02:31:45 UTC Tue Aug 23 2016
System image file is "flash0:c2900-universalk9-mz.SPA.155-1.T2.bin"
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 EvalRightToUse securityk9
uc uck9 EvalRightToUse uck9
data datak9 EvalRightToUse datak9
C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time 1w0d ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC20233V3R
Hardware Revision : 1.0
Part Number : 73-11833-12
Top Assy. Part Number : 800-30797-06
Board Revision : J0
Deviation Number : 519064
Fab Version : 03
Product (FRU) Number : CISCO2911/K9
Version Identifier : V07
CLEI Code : CMMJD00ARA
Processor type : C1
Chassis Serial Number : FGL2026107D
Chassis MAC Address : 00f6.637d.bc28
MAC Address block size : 80
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 32 30 32 33 33 56 33 52 40
0x10: 06 18 41 01 00 82 49 2E 39 0C C0 46 03 20 00 78
0x20: 4D 06 42 4A 30 88 00 07 EB 98 02 03 CB 8C 43 49
0x30: 53 43 4F 32 39 31 31 2F 4B 39 89 56 30 37 20 D9
0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 4A 44 30 30 41 52
0x50: 41 09 C1 C2 8B 46 47 4C 32 30 32 36 31 30 37 44
0x60: C3 06 00 F6 63 7D BC 28 43 00 50 C4 08 00 00 00
0x70: 00 00 00 00 00 F3 00 03 40 01 25 FF FF FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Internal Power Supply information
Top Assy. Part Number : 341-0235-07
Deviation Number : 0
PCB Serial Number : DCA2018R0JB
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V05
Product (FRU) Number : PWR-2911-AC
CLEI Code : 0000000000
Board Revision : A0
0x00: 04 FF 40 05 E5 DF 45 01 55 00 EB 07 88 00 00 00
0x10: 00 C1 8B 44 43 41 32 30 31 38 52 30 4A 42 03 00
0x20: 81 00 00 00 00 04 00 89 56 30 35 20 CB 8B 50 57
0x30: 52 2D 32 39 31 31 2D 41 43 C6 8A 30 30 30 30 30
0x40: 30 30 30 30 30 F3 00 59 41 00 BE 42 00 05 F8 00
0x50: 50 01 F3 15 97 02 F0 18 3B 03 E6 19 FB 04 E2 1B
0x60: 1C 05 D9 1C 53 06 D8 1D 4F 07 D6 1D B6 08 CE 1E
0x70: 40 09 C2 1E ED 0A B8 1F B1 0B B9 20 20 0D AF 20
0x80: 86 0F 9B 20 ED 11 91 21 3F 13 87 21 62 17 74 21
0x90: C0 1B 57 21 DB 1F 38 21 F3 23 25 21 FC 27 0A 21
0xA0: F3 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
Total platform memory : 524288K bytes
Total 2nd core memory : 0K bytes
Start of physical address for 2nd core : 0x80000000
Virtual address start of 2nd core memory : 0x0 - 0x0
2nd core configured disabled
L2 cache ways for 2nd core : 0
IGW01#sh ver
2 Accepted Solutions
Mark Malone
Hii
pbase on 2900 should support basic eigrp , what options does it show you in conf mode when you do
(conft) router ?
Technology Package
Details
Software Activation Feature Licenses
Right to Use Feature Licenses
IPBaseK9
Offers features found in IPBase IOS image on ISR 1800,2800 and 3800 + Flexible Netflow + IPV6 parity for IPV4 features present in IPBase. Some of the key feature are AAA BGP, OSPF, EIGRP, ISIS, RIP PBR IGMP, Multicast DHCP HSRP, GLBP NHRP HTTP HQF QoS ACL, NBAR GRE CDP, ARP NTP PPP PPPoA PPPoE RADIUS TACACS SCTP SMDS SNMP STP VLAN DTP IGMP Snooping SPAN WCCP ISDN ADSL over ISDN NAT-Basic X.25, RSVP, NTP, Flexible Netflow etc.
None
None
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
edit: Checking feature navigator on cisco website it says that image supports eigrp on ipbase as per screenshot
Palani Mohan
Hi Paul
Copy/pasting your output that is easy on eyes:
This tells me you ipBasek9. This feature set 15.5(1)T2 seem to accept router eigrp cmd fine?
R2911(config)#router eigrp 123
R2911(config-router)#
R2911(config-router)#do sh run | sec router
router eigrp 123
Do you have a session log with what you experienced?
Kind regards .... Palani
Mark Malone
Hii
(conft) router ?
Technology Package
Details
IPBaseK9
None
None
Palani Mohan
Hi Paul
router eigrp 123
