Cisco6500
Lavanholy
Hi ,
I have purchased Cisco6509 chasis and Ethernet 48 port module and GBIC fiber module as a replacement,Now I want to check the ethernet switch and gibic module by populating the Cisco 6509 switch,How to check the modules without SUP engine?
Without SUP engine,I f I power on the switch ,Will the switch port LEDS will power ON and OFF,or what is teh symptom I can notice while Powering ON the Cisco without SUP engine.
Please help me.
Thanks and Regards,
S.Venkataraman.
ankbhasi
Hi Venkat,
No line cards will come up without a sup engine. Sup engine is the heart and brain of the chassis.
Without sup engine if you insert the line cards they are dump devices and will not come up.
Ankur
*Pls rate all helpfull post
Hi Ankur,
