CiscoSwitch 4500-X login trouble
samuelogalli
Hi Team
I have 2 4500-X switches which when I console to them to do a password recovery, some characters on my keyboard do not work when I type. when I go to romon mode. what could be the issue?
Leo Laohoo
Some characters do not work?
Have you tried other machines?
Hi Leo
Yes we have other switches plus 2 Cisco ASAs, they work very fine. I tried to boot in rom mode, but i can't type commands to change the registry for password recovery
balaji.bandi
Can you post an example here, and change the baud rate and check if that works?
below standard :
Configure the baud rate and character format of the PC or terminal to match these console port default characteristics:
  • 9600 baud
  • 8 data bits
  • 1 stop bit
  • No parity
  • None (flow control)
BB
Hi balaji
I have noticed flow control doesn't match could this the reason for the problem on my keyboard? please find attached.
