class default qos
tedauction
Level 5
Level 5
Hello, if I apply the following policy map to an interface, does this simply make all traffic on that interface get marked with EF ?
policy-map CODEC
 class class-default
  set dscp ef
Mark Malone
I wouldn't use the default qos map that's only for when all other policy statements have been set and whatevers left the default class will use for bandwidth  , set your own policy and apply it to the interface to match traffic coming in ., you can tighten it to the voice subnet in the acl
class-map MAPVOICE
match access-group 100
policy-map TEST
class MAPVOICE
set dscp EF
access-list 100 permit ip any any
Hello
Yes it does if you apply it to an interface.
note:
ip dscp ef= ivp4 packet
dscp ef = ipv4 and ipv6 packets
res
Paul
Kind Regards
Paul
Joseph W. Doherty
Yes, although if used as an ingress policy, another port's egress policy could remark the traffic.
