clear config - interface
dkblee
Level 7
Level 7
hi! what's the command to clear an gigaethernet internface config on a 4506e sw? currently there are lots of qos and security stuffs on some of the gigaethernet port. instead of using the no command for each of the line, is there a command to clear all these config? i just want to configure access vlan on the port.
thx.
Lim Seow Hua
Level 3
Level 3
You can try to use below command on the configuration mode....
xxx-xxx(config)#default interface gigabitEthernetx/x - specify the port that you would like to clear the configuration...see whether it works or not.
And let me know later
7 Replies 7
Lim Seow Hua
Level 3
Level 3
Hi there,
I tried the above command and it works.
Worked for me too, thanks!
Worked for me as well.
Thanks!
BTW, I recall the interface default command can be use with the interface range command too.
Thank you!!
I did have to type it as autocomplete wouldn't work for some reason?
Either way it worked and thank you !!!
Bahusafoo
Community Member
Wanted to say, this works with ranges too.  IE to default ports 1-22 on a switch from conf t:
default int range gi1/0/1-22
