Clear Interface
bdulipala
Community Member
Switchport showing up and reset the switchport still it's down and cleared the counters on interface no luck. I would like to clear interface int-ID clear hardware logic how it will effect and is it solves the issue.
Bala
7 Replies 7
bdulipala
Community Member
Access pont connected to the switch..
Your help is much appriciated..thanks.
What switch series and model do you have?
What IOS version?
also can you provide more detail on the issue?
(C2950-I6Q4L2-M), Version 12.1(22)EA4
The Access point is down and I reset the interface and clear the
counters on the interface as well but it come online. I would like to
know how the clear interface fasethernet works and how its effect (As I
see clear hardware logic). Could you please let me know what will be
effect of this command.
I have available options..to make the access point up..
1. I can talk to site and pull the cable....
2. I can take backup config and erese and wr once again with duplex and
speed..on the switchport.
3. Reboot the access point.
But however, I would like to know do we have option to soft reboot the
fastethernet interface. Like service-module in the router.just an
example. Thanks for your help.
Bala
To reset an interface, enter into interface configuration mode and issue the 'shutdown' and 'no shutdown' commands. This will bring the interface down then up like as you would reconnect the cable physically.
Switch# conf term
Switch(config)# interface FastEthernet0/1
Switch(config-int)# shutdown
Switch(config-int)# no shutdown
To clear the interface counters, use the 'clear counters FastEthernet0/1' command or 'clear counters' to reset the counters on all interfaces.
Andras
This is not my expected question was about I already used them. I would like to know how the clear interface int-id works. Pls help me with the same.
"default interface "  will clear all non-default configs.
