clear ip ospf process command not working
plasmapup959
Community Member
Hello, I am trying to set a router-id and then clear ip ospf process as required, but and Invalid input error appears instead. Please help, Thank you in advance!!
You need to exit to enable mode
Then do
Clear ip ospf prco
MHM
Then do
Clear ip ospf prco
MHM
Hi @plasmapup959 ,
If you want to run this command from the configuration mode, you need to use "do clear ip ospf process". You could also exit the configuration mode and then use "clear ip ospf process" as suggested by @MHM Cisco World .
BTW, FYI, the configuration "do" command allows for all the other execution commands.
