Showing results forĀ
Search instead forĀ
Did you mean:Ā
%IPV6_ND-6-DUPLICATE INFO: DAD attempt detected for
Lance Wendel
Hi all,
my customer has added IPv6 to their  BYOD WLAN subnet and are seeing  the following log messages on their Cat6k syslog
%IPV6_ND-6-DUPLICATE_INFO: DAD attempt detected for FE80:: on VlanABC
%IPV6_ND-6-DUPLICATE_INFO: DAD attempt detected for FE80:: on VlanXYZ
%IPV6_ND-4-DUPLICATE_OPTIMISTIC: Duplicate address FE80:: on VlanYYY
%VRRS-6-INFO: Internal info, VlanABC: Duplicate address detected on the network FE80:: -Process= "IPv6 Input", ipl= 0, pid= 577
The  FE80:: is their LL-HSRP IPv6 address for these vlans . It seems that quite a number of clients is probing the RA  address.
my customer is querying if there is a way to disable this?
any advice please?
thanks in advance
Lance
7 Replies 7
cadet alain
the clients that are probing this address is normal if they have it configured as they ipv6 default gateway.
DAD attempts is normal way for IPv6 to test if it can use an IP.
The only problem I see here  is that for VlanABC there was a duplicate address detected by the catalyst but I'm not an expert with this platform so I can't tell if this is  problematic here.
Alain
hara12386
I am facing the same issue, have you found a fix?
Many thanks,
Hamid
Hi @hara12386 ,
This post is 10 years old. Could you please open a new request and provide the relevant information.
hara12386
Hello @Harold Ritter
Thank you for your feedback, I found the following bug CSCvd81898 that fits, so I applied the workaround and I am monitoring the situation.
In case it won't fix the issue, I will open a new request.
Thank you,
Hamid
Thanks @hara12386 . Let us know if the workaround for CSCvd81898 does not solve the issue.
hara12386
Just to let you know that this didn't fix the issue, I had to open a case with cisco TAC that is still in progress..
Many thanks,
Hamid
Hi @hara12386 ,
Thanks for the feedback. Another work around would be to disable DAD with the following command under the interface:
ipv6 nd dad attempts 0
