Clearing Configuration
fmirza007
What command should I use to clear all my configs off of a Sup720 running 12.2(33)SXI2a
I have tried clear config all but it doesn't recognize that command??
Lucien Avramov
Level 11
Level 11
write erase
and reload
Lucien Avramov
Level 11
Level 11
write erase
and reload
CoetzerJ
Level 2
Level 2
You might also want to delete the VLAN database if you had VLANs etc configured by doing a 'delete flash:vlan.dat' and also delete any crashinfo files from sup-bootflash.
