HUB and spoke setup - can't ping
mbroberson1
Level 3
Level 3
What's wrong with this lab configuration setup? Can't ping the routers loopbacks.
***L3 Switch***
ip routing
interface FastEthernet1/0/1
description R1 interface
switchport access vlan 210
switchport mode access
interface FastEthernet1/0/2
description R2 interface
switchport access vlan 200
interface FastEthernet1/0/3
description R3 interface
switchport access vlan 220
interface Vlan200
ip address 10.20.1.1 255.255.255.252
interface Vlan210
ip address 10.101.104.1 255.255.255.252
interface Vlan220
ip address 67.33.21.153 255.255.255.252
ip classless
ip route 10.24.25.0 255.255.255.0 10.20.1.2
ip route 10.101.8.0 255.255.255.0 10.101.104.2
ip route 172.16.0.0 255.255.0.0 67.33.21.154
***R1***
interface Loopback0
ip address 10.101.8.1 255.255.255.0
interface FastEthernet0/0
ip address 10.101.104.2 255.255.255.252
duplex auto
speed auto
ip route 10.24.25.0 255.255.255.0 10.101.104.1
ip route 172.16.0.0 255.255.0.0 10.101.104.1
***R2***
interface Loopback0
ip address 10.24.25.1 255.255.255.0
ip address 10.20.1.2 255.255.255.252
duplex auto
speed auto
ip route 10.101.8.0 255.255.255.0 10.20.1.1
ip route 172.16.0.0 255.255.0.0 10.20.1.1
***R3***
interface Loopback0
ip address 172.16.1.1 255.255.255.0
ip address 67.33.21.154 255.255.255.252
duplex auto
speed auto
ip route 10.24.25.0 255.255.255.0 67.33.21.153
ip route 10.101.8.0 255.255.255.0 67.33.21.153
Edison Ortiz
You aren't advertising your LAN interfaces. Try pinging while sourcing from the loopback, for instance:
R1:
ping 10.24.25.1 source lo0
Edison
Edison Ortiz
R1:
Edison
Thanks Ed,
You are correct. I was not sourcing from the loo. I just realized that before I checked this post. I appreciate you replying.
Not a problem Brandon and thanks for the rating.
Edison
