CLI Output filter - show int counters errors
ju.mahieu
Level 4
Level 4
On catalyst and Nexus, I would like to filter the lines with 0 0 0 0 0 from the "show int counters errors" result.
Result without filter :
Switch#sh int counters errors
Port        Align-Err    FCS-Err   Xmit-Err    Rcv-Err UnderSize OutDiscards
Gi1/1               0          0          0          0         0           0
Gi1/2               0          0          0          0         0           0
Gi1/3               0          0          0          0         0           0
Gi1/4               0          0          0          0         0           0
Gi1/5               0          0          0          0         0           0
Gi1/6               0          0          0          0         5500     0
Gi1/7               0          0          0          0         0           0
Gi1/8               0          0          0          0         0           6005
My expected result
Switch#sh int counters errors | exclude or grep ???
Thank you for your help.
Regards.
Ju
10 Replies 10
OMAR CANDARAVE
Please try with:
sh int counters errors | ex "0 \+0 \+0 \+0 \+0 \+0"
In Nexus switch and let me know.
Hello Omar,
It works great on my nexus. Thank you.
But not on my catalyst 6k. Argh
Try this.
sh int counter | ex 0          0          0          0         0           0
CF
This should also work.
sh int counters | ex 0(.*)0(.*)0(.*)0(.*)0(.*)0
CF
This one almost works 🙂  but it filters also the lines with Gi0/2 ....
Ju
I assume any interface that is being left out,  interface counter value is ending at 0 for that interface. eg:12340
These kind of lines are filtered:
sh int counters errors | ex 0(.*)0(.*)0(.*)0(.*)0(.*)0
Gi1/0/12            0           0           0           0          0           83
Gi2/0/20            0           0           0           0          0      5343759
Gi2/0/21            0           0           0           0          0      5343135
Gi2/0/22            0           0           0           0          0      5344382
Po2                 0           0           0           0          0          104
Ju
thank you but it doesn't work.
Ju
uday singh
Visitor
This should do it:
sh int counter erro | in ^(.+ )[123456789]|Port
NOTE:  there is a white space after the '+' sign.
