Clients not able to ping each other
par13
I'm getting configure several cisco 3550s. So far every new switch configuration works fine. However, when I go to 24 port switches and upload this configuration "the switches are able to ping each other". But, "the computer can not ping each other"
en
Config t
hostname LV-126A-W-13-3
enable secret 5 $1$27ar$DnvrYBhnNW5eyTF2JgHIe.
enable password 7 0307585A5E5A744058
username admin password 7 1414115A54517F2732
!no aaa new-model
!ip subnet-zero
ip domain-name lv.psu.edu
ip ssh version 2
int range f0/1 - 24
switchport mode dynamic desirable
description Wireless
switchport access vlan 300
interface GigabitEthernet0/1
description Trunk to Cisco6509 router
switchport mode trunk
no shut
interface GigabitEthernet0/2
interface Vlan1
ip address 172.31.13.3 255.255.255.0
no shut
interface Vlan300
description Academic
no ip address
no ip route-cache
no shut
ip classless
ip http server
ip http secure-server
banner motd #
** WARNING: Unauthorized access to this system **
** is forbidden and will be prosecuted by law. **
** By accessing this system, you agree that your **
** actions may be monitored if unauthorized usage **
** is suspected. Only authorized Penn State **
** Lehigh Valley Campus **
line con 0
exec-timeout 0 0
line vty 0 4
password 7 1511085D5C7F7E283E
login local
transport input telnet ssh
line vty 5 15
password 7 094F4D584150421E1D
no login
end
wr
johnlloyd_13
Level 9
Level 9
is your goal to ping between PCs on the same VLAN or between VLANs.
int range f0/1 - 24
switchport mode dynamic desirable -> change this to 'switchport mode access'
also, make sure you've created vlan 300 and assign an ip address for int vlan 300
interface Vlan300
no ip address -> add ip address here
The ip address on vlan 300 does it need to be the same as the pc?
if I set the vlan to switchport mode access, how does that affect two separate subnets?
I don't want subnets to see each other.
Leo Laohoo
Where is VLAN 300 in your VLAN Database? This is a WS-C3550 right?
In config mode, enter "vlan 300" and this should be fine.
