Showing results forĀ
Search instead forĀ
Did you mean:Ā
cold start
prashantrecon
Level 7
Level 7
Hi Team,
we haven't rebooted the switch but still logs show it has udergone a coldstart is there any hardware eeror
000007: *Jan  4 02:16:13: %SNMP-5-COLDSTART: SNMP agent on host nihilent01 is undergoing a cold start
00:00:34: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
00:00:35: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 16-Aug-07 11:57 by integ Build [100]
00:00:36: %OIR-6-CONSOLE: Changing console ownership to route processor
00:00:36: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:01:43: SP: SP: Currently running ROMMON from S (Gold) region
00:01:52: %SPANTREE-SP-5-EXTENDED_SYSID: Extended SysId enabled for type vlan. The Bridge IDs of all active STP instances have been updated, which might change the spanning tree topology
00:01:57: %OIR-SP-6-INSPS: Power supply inserted in slot 1
00:01:57: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
00:01:58: %OIR-SP-6-INSPS: Power supply inserted in slot 2
00:01:58: %C6KPWR-SP-4-PSOK: power supply 2 turned on.
00:01:58: %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
00:01:58: %SYS-SP-5-RESTART: System restarted --
Cisco IOS Software, s72033_sp Software (s72033_sp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXH, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sun 19-Aug-07 07:52 by prod_rel_team
00:01:59: %SYS-SP-6-BOOTTIME: Time taken to reboot after reload =  156 seconds
*Jan  4 02:16:26: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Jan  4 02:16:26: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 6 became active.
*Jan  4 02:16:28: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
000008: *Jan  4 02:16:50: %SNMP-5-MODULETRAP: Module 6 [Up] Trap
*Jan  4 02:16:49: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online Diagnostics
*Jan  4 02:16:50: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
00:00:02: DaughterBoard (Centralized Forwarding Card)
7 Replies 7
rsimoni
no error message in bootup logs; first impression is that you got a power cut.
please paste the following:
show module
show version
remo com sw show version
remo com sw show nvlog
show diagnostic events
if you have redundant supervisor take also:
rem command standby-sp show nvlog
show redundancy
show redundancy switchover
regards,
Riccardo
i
Please find the details below
nihilent01#show redundancy
Redundant System Information :
       Available system uptime = 8 hours, 35 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Simplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Down      Reason: Simplex mode
Current Processor Information :
               Active Location = slot 6
        Current Software state = ACTIVE
       Uptime in current state = 8 hours, 34 minutes
                 Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXH, RELEASE SOFTWARE (fc5)
Compiled Sun 19-Aug-07 07:38 by prod_rel_team
                          BOOT = sup-bootdisk:,1;
                   CONFIG_FILE =
                       BOOTLDR =
        Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED' state
nihilent01#show redundancy switchover
Switchovers this system has experienced          : 0
Last switchover reason                           : None.
Uptime since this supervisor switched to active  : 8 hours, 36 minutes
Total system uptime from reload                  : 8 hours, 36 minutes
nihilent01#show module
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1202CRVV
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1202CN7J
  5    2  Supervisor Engine 720 (Other)          WS-SUP720-3B       SAL114990M2
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL114990M2
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001e.bef8.6cd0 to 001e.bef8.6cff   2.7   12.2(14r)S5  12.2(33)SXH  Ok
  2  001e.f77f.b500 to 001e.f77f.b52f   2.7   12.2(14r)S5  12.2(33)SXH  Ok
  5  0016.9de6.6200 to 0016.9de6.6203   5.6   Unknown      Unknown      Other
  6  0016.9de6.6200 to 0016.9de6.6203   5.6   8.5(2)       12.2(33)SXH  Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1202CRJT  4.0    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1202CRK6  4.0    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B       SAL1149978X  2.3    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL114992AD  3.1    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  5  Not Applicable
  6  Pass
where is the rest of the outputs I requested?
I have some ideas of what heppened but I need all the outputs I requested (some of them will not give any info as the sup on slot 5 is not Other - probably in ROMMON - but I could get some valid info from the other outputs I asked you).
You'd better paste all the outputs in a txt file and attach it to this thread.
Slot 5 and 6 are currently occupied by a pair of Sup720.  Active card is Slot 6.  Maybe Slot 5 Sup720 is running a different IOS?  Have you tried to remove and re-insert the card and see what happens?
HI Leo,
Are u taking about slot 5 to remove and re-insert .
Hi Prashant,
do you want to solve the 'other' status of your sup or do you want to know why the switch reloaded?
Riccardo
Yes.
