Collect pcap via console cable
apuseljic1
Hello all,
is it possible to export "monitor capture" file from a CUBE via serial console cable to the PC? There is no telent/ssh connection, only via serial console cable.
Anthony
balaji.bandi
I do not believe it is possible directly using a serial cable - option optin you can  Log(not capture) stored to PC based on the client utility used to connect via serial cable. example putty/secure CRT.
you can configure another way to push over the network as per below thread :
https://community.cisco.com/t5/collaboration-voice-and-video/ip-traffic-export-packet-capture/ta-p/3148122
BB
