Combining multipe ACL's
Mike Hulme
Community Member
I have a lot of VLAN's on the network and require the same set of ACL's for each VLAN with only a minor addition. Therefore, is there a way to create a default ACL and combine it with another ACL then add to the the interface. This will save a lot of thime and propogate ACL changes to all interfaces in the future.
ip access-list extended DefaultACLinbound
      permit ip x.x.x.x m.m.m.m
ip access-list extended Building26ACLinbound
DefaultACLinbound + Building26ACLinbound = B26ACLinbound
Interface vlan 260
     ip access-group B26ACLinbound in
Mike
5 Replies 5
nkarthikeyan
Level 11
Level 11
Hi Mike,
As far as i know you cannot do that in VACL/Routed interface ACL rather you can do that only for Qos using class-map and policy map.
Am not sure if this feature is available in latest versions also.
By
Karthik
yes, as far as i know Karthik is right.
But what do your subnets look like? Can you combine the subnets so that you can get all statements into one acl instead of 2?
This is what i do overhere (as far as possible with my subnets) and that way i have one and the same acl on many interfaces.
Something like
Extended IP access list traffic-to-server-outside
10 permit tcp 10.1.64.0 0.0.63.255 any eq ftp-data  (all subnets from 10.1.64.0 to 10.1.127.0)
20 permit tcp 10.1.144.0 0.0.7.255 any eq ftp-data  (all subnets from 10.1.144.0 to 10.1.151.0)
etcetera
Thanks for your help. shame there is no easy solution.
Mike
you can with a router in same ACL list
Joseph W. Doherty
As also noted by others, unaware of Cisco routers or L3 switches supporting nested/called ACLs for interfaces.
However, it wouldn't be an insurmountable problem to have a script merge ACLs into a combined ACL, perhaps even by an EEM script.  (To make the scripting simpler, you might use specific ACL names and/or embedded ACL remark statements, to help a script identify what should be merged into an applied composite ACL.)
