Combining two cable lines with one layer 3 switch
mirsalaradili
I hope someone can help me since it is not a big problem.
I have two internet lines in my office. Since there is too much traffic on one of them and sometimes drop wireless clients, I need to add the other cable line to the first one with a layer 3 switch and use them as one wireless connection. How can I do it?
10 Replies 10
mirsalaradili
Also I need redundancy and load balancing on it... I appreciate it if someone could give an answer.
Anyone? Please, I have to have an answer today...!!
Alvaro Garcia
I'm afraid I dont fully understand what you are trying to do... I undertand you have two internet connections and one of them is oversubscribed...what do you mean with "add a second cable line"?
Please elaborate more and provide topology if possible...
Well there is a wireless router which provides the internet here. The traffic on it made us to buy a new internet line. Both of them are DSL. We have another wireless router for the new internet line. The question is how can I combine these two internet lines with a layer three switch, so i can have load balancing, redundancy and bandwidth sharing at the same time?
Alvaro Garcia
That's quite task you are trying to accomplish... I would suggest you to check the following post:
http://www.dslreports.com/faq/14086
Thanks for your help. I read the article. Although I need more details and your opinion about which way do you think is the best. What equipment do I need and what is the best way to do such thing? Also I would appreciate a detailed process description.
Thanks again in advance
What if I just wanted to set a load balancing for my two cable internet lines which by the way are from the same ISP?
Please instruct me what to do...
What model of a router or switch do you have?
If you say you have a switch what IOS and feature set do you have on?
I have a Cisco layer three switch which i dont know the model now, but any device required will be provided. Although we rather to spend least amount of cost. The routers are comcast.
That sure is a very vague "description".
Load Sharing with BGP in Single and Multihomed Environments
