Command Auto complete in CLI problem
Jimi_patel
Community Member
I have problem with the command auto completion in packet tracer's CLI. I was trying that with the 'Tab' key, but it's not working. Is there any other method for command auto completion?SwitchingFAQF,A,Q
Jimi_patel
Community Member
it works for those commands that are in packet tracer. PT is a software simulator to simulate real IOS but it is not real IOS so some commands are missing and some behavior is simplified.
Regards, ML
**Please Rate All Helpful Responses **
luis_cordova
Hi @Jimi_patel
The autocomplete function works when the entered command leaves no other possible option.
For example, in a switch layer 3, if you enter ip rout and press tab, the command will not complete, since there is more than one possible option (ip route and ip routing).
For this reason, I suggest you review that what was entered before the tab does not leave more than one possible option.
