command for checking performance of L3 SWITCH
knaik99
one of my site has L3 switch as core and I want to check whether this switch would be getting loaded with routing and switching processes for last 7days so what is command to check that i.e. performance of that L3 switch?
9 Replies 9
Mark Elsen
        - That would depend on the particular model/type ,can you share ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
C9300-24T-E
I think the most you can do on a L3 switch is check utilization for the last 72 hours, by using the command:
L3Switch#show processes cpu history
Leo Laohoo
What OS?  IOS or IOS-XE?
C9300-24T-E
@knaik99 wrote:
C9300-24T-E
Ok, we're playing "20 questions" are we?
Ok, what is the exact firmware of the switch running on?
balaji.bandi
we need to know what is the version of code running and you have any NMS you can monitor
here is troubleshoot guide :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-5/configuration_guide/sys_mgmt/b_165_sys_mgmt_9300_cg/troubleshooting_the_software_configuration.html
BB
Mark Elsen
 - Besides other replies you may also look into CIsco Prime, a network management tool, which offers an easy performance dash-board for core switches (too). You will also get notified , if core uplinks get saturated , for instance.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
On a side note, Cisco Prime is definitely good...but even the most basic 50 device license costs >$5,000. So it is not cheap...;)
