Command rejected: conflicts with IPv6 Snooping (FHS)
I am trying to bring up a port channel using LACP active. Previously, when I would try to bring the ports online it would cause a loopback error. Today I was able to get onsite again and tried configuring it from the edge switch via serial cable. I brought both SFP ports down, and attempted to configure them as a range in hopes of avoiding any loopback errors, but instead I was met with the following:
XXX-YYY-SWT-01(config-if-range)#channel-group 1 mode active
% Interface range command failed at TenGigabitEthernet1/1/2
Exiting from range submode without applying rest of the commands in range to avoid unwanted issues
The only things I can find online in relation to this aren't providing much inside other than the obvious, I need to turn off ipv6 snooping. I am having a hard time finding a solution or even how to turn it off. Again, maybe I'm overlooking something.
Other things to highlight/mention are
Cisco IOS XE Software, Version 17.06.05
Cisco IOS Software [Bengaluru], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.6.5, RELEASE SOFTWARE (fc2)
Show run int po1:
interface Port-channel1
description TCA-01
switchport trunk allowed vlan 1,5,20,50,80,100,200,950,2110
switchport mode trunk
device-tracking attach-policy MERAKI_POLICY
Show run int Te1/1/1:
interface TenGigabitEthernet1/1/1
description TCA-01
auto qos trust
service-policy input AutoQos-4.0-Trust-Cos-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
end
Show run int te1/1/2:
interface TenGigabitEthernet1/1/2
description TCA-01
ip flow monitor MERAKI_AVC_IPV4 input
ip flow monitor MERAKI_AVC_IPV4 output
shutdown
ipv6 flow monitor MERAKI_AVC_IPV6 input
ipv6 flow monitor MERAKI_AVC_IPV6 output
auto qos trust
end
I don't think it is the meraki monitoring that is causing this problem. Any ideas is welcomed!
I finally got back around to troubleshooting this problem and it was caused by Meraki Dashboard Monitoring that we had set up. We don't use Meraki for config pushes, just monitoring devices and network health. I learned that I needed to remove the switch stacks from Meraki Dashboard, configure the port-channels etc, and then add the switches back to Meraki to avoid the ipv6 snooping and device tracking. Both interfaces are joined to the port channel and functioning. Thank you for pointing me in the right direction. Cheers!
marce1000
  - Do you have any command in the running configuration as in :  ip device tracking maximum ...
    If so , remove it and try again,
 M.
Sorry for the delayed response - The only things related to tracking or glean that I can find in the running-config are from the Meraki monitoring account that is used.
I'm currently finding the time to recreate this is a virtual lab or with some spare switches to figure out what is going wrong.
To confirm against the great Marce1000, when bringing up an port channel for the first time, it's best to do so by taking the interfaces down, configuring them to the channel-group mode, and bringing them up together as a range? Does it really matter if I start on the edge vs the core?
Thank you in advance for your help!
shuaiguy
I ran into this today and found this post. I realized that removing the "device-tracking attach-policy MERAKI_POLICY" command from interface fixed the issue. Once that command is removed, you can assign it to the channel-group.
