command to leave switch description blank
Cnote100
Community Member
            What is the command to leave description blank?
InayathUlla Sharieff
Very easy just remove the description.
As you know that by default there would be no description configured on the port, But if someone have configured it and you want to remove  the same you can do it by just removing the same.
Eg:
Router#sh run int e0/0
Building configuration...
interface Ethernet0/0
description SERVER >>>>>>>>>>>>> Description has been confiugred as Server.
ip address 192.168.0.1 255.255.255.0
end
2- Now I am removing that description:
Router(config-if)#int e0/0
Router(config-if)#no des
Router(config-if)#no description
Router(config-if)#do sh run int e0/0
ip address 192.168.222.27 255.255.255.248
end >>>>>>>>>>>>> No description now.
Inayath
*Plz rate this thread is this answerd yoru query.
Eg:
end
Inayath
Perfect!!!!!   Just tried it... worked like a charm.....
