Upgrade 2960-S flex stack how long does it take?
pcdap
I do not have any stacked 2960s switches to "lab" a stack upgrade.  Have a 4-switch (48-port FPS switches) production stack, and will use the archive- command, but is the process verbose or will the console just sit there leaving me wondering?  About how long might it take?  Going to upagrade from 15.0(2)SE2 to SE4.  I don't see a nice logged output of the upgrade process anywhere on the Cisco site.
Thanks.
Debbi
Leo Laohoo
There are two "branches' of the archive command, exactly which one will you be using?  The second one, "archive tar /x" is not useful for stacked switches.
If you have a full 4-stack switch, the "archive download-sw" will automatically push and un-pack the IOS to any stack members of the stack.  If I remembered correctly, it takes about 8 to 10 minutes per switch.
Sorry, archive download-sw is the one I will use.  Thanks for the time estimate!
Debbi
