Communicate between Different VLAN in same subnet
ankitohc
Hi Team,
I have one L3 switch and two PC with different VLANs
I know we can't have same subnet for different VLAN's however using this topology.. How can i archive this?
and I can add more devices on top however will not change the configuration.
how VLAN 1 will communicate with VLAN 2 - PC on left to PC on right
17 Replies 17
M02@rt37
hello @ankitohc
happy new year !
As concerned your topology, what is the mask of PCs ? regarding IP addresses PC seem to be in the same subnet no ? then it should be the same vlan id no ?
As concerned routing between two PCs on that Switch ; 2 PCs on different subnet and vlan, you need to activate ip routing on that L3 Switch.
Best regards
Happpy new year Buddy
PC 1 on left side 10.10.2.1/24 VLAN  1
PC 2 on right side 10.10.2.2/24 VLAN 2
They are on same subnet with different VLANs
@ankitohc
It is not possible for two devices on the same physical network to be in the same subnet with different VLANs. VLAN are used to logically segment a network into multiple broadcast domains, allowing different VLANs to operate as if they were on separate physical networks.
In your scenario, PC 1 and PC 2 are assigned to different VLANs (VLAN 1 and VLAN 2, respectively). Each VLAN should have its own unique subnet to ensure proper network segmentation. If they share the same subnet (10.10.2.0/24 in your example), they would be part of the same broadcast domain, defeating the purpose of VLANs.
To correct this, you should assign different subnets to each VLAN. For example:
  • PC 1: 10.10.1.1/24 (VLAN 1)
  • PC 2: 10.10.2.1/24 (VLAN 2)
Best regards
  • Yes I know that is general practice which we learn from books however still Is there any way to communicate within same subnet and adding any router or using VRF or something I am just asking.. I can be wrong as well
@ankitohc
If you want to make devices in different VLANs communicate while being in the same IP subnet, you could use a Layer 3 device (like a router) to route traffic between the VLANs.
Best regards
what should be configuration if i use router?
the different vlan break the broadcast which need to Know the MAC
so use router instead of PC
then add MAC manually
and try ping
MHM
Joseph W. Doherty
The basic problem you have, the same network is expected to be within the same L2 domain.
You could do what you ask using NAT, such that each VLAN/subnet "sees" the other subnet as not part of itself.  For example each VLAN might be 10.10.2.0/24 and "see" the other VLAN's network as 10.10.3.0/24.
Most L3 switches don't support NAT, but most routers would.
Torbjørn
I assume this is for a theoretical lab exercise? I would not recommend doing this in any kind of production network. The simplest way to achieve this is bridging the VLANs by connecting a VLAN 1 access port to a VLAN 2 access port on the switch and enabling BPDU filter on the ports.
If it was a different VLAN than VLAN 1 you could have used private VLANs to achieve this. You could have done so by configuring one of the VLANs the primary VLAN while configuring the other VLAN as a secondary VLAN.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Can you please share the configuration?
Are you running EVE-ng?
If it allows you to connect a device to itself you can connect port Gi0/2 to Gi0/3 and enter the following config:
int gi0/2
switchport mode access
switchport access vlan 1
switchport nonegotiate
spanning-tree bpdufilter enable
no cdp enable
int gi0/3
switchport access vlan 2
no cdp enable
If it doesn't allow you to connect devices to themselves you can achieve the same thing by adding another switch and connecting the switches like so: SW1 Gi0/2 - SW2 Gi0/3, SW1 Gi0/3 - SW2 Gi0/2 and apply the same lines of config to both switches.
Although bridging the VLANs is possible, you effectively create one combined VLAN, which negates the point of having separate VLANs.  Of course as a "theoretical lab exercise", sure, why not.  Otherwise as you also write "I would not recommend doing this in any kind of production network."
BTW, what I suggested might be used in a real world situation when you merge companies having overlapping private IPs.
Yes you are right meger companies in a real world situation, however can you please help me with command.. I am not sure how to configure bridge VLANS
As @Torbjørn wrote "The simplest way to achieve this is bridging the VLANs by connecting a VLAN 1 access port to a VLAN 2 access port on the switch and enabling BPDU filter on the ports."
You may wish to also disable CDP on those ports, as it will complain about the VLAN mismatch.
