Communicate between VLANS on different VTP Domains
jon.baxter1
I have 5 vlans in a vtp domain called SWA.  Here are two of the vlans
Vlan 100
192.168.100.0 255.255.255.0
Vlan 200
192.168.200.0 255.255.255.0
and the SVI's
192.168.100.1 255.255.255.0
192.168.200.1 255.255.255.0
I also have dhcp pools for them and they are working properly
I have one vlan in a vtp domain called SWB.  here is the vlan and the svi
Vlan 200
192.168.200.2 255.255.255.0
I have a trunk port connected between the switches.  I have a host connected on SWB in vlan 200.  It gets an IP address from SWA, it can ping 192.168.200.1.  It cannot ping a host device on SWA in vlan 100.
I cannot figure out why.  I thought I have done everything.  I understand that vlan 200 is talking across the vtp domains, but why wont the device in vlan 200 in the vtp domain SWB talk to the device on vlan 100 in SWA?
Any insight is greatly appreciated.
cofee
Level 5
Level 5
You can verify the following to troubleshoot the issue:
1) On the switch where both SVIs are configured, please make sure that one SVI can ping the other, you can test it like this , ping 192.168.100.1 source 192.168.200.1, if this doesn't work then this needs to be fixed before you try anything else.
2) Make sure both end devices can ping their default gateways (SVIs interfaces) and both end devices have default gateways configured.
