STP root bridge and Layer 2 Switch
mahesh18
Level 7
Level 7
Hi Everyone,
I have quick question about STP Root bridge
The device is not Cisco device
Sw1 is layer 2 switch with data vlan 10
Sw2 is layer 2 switch with multiple vlans
Sw3 is Core Layer 3 switch with Layer 3 interfaces for all  the vlan.
(Vlan 10 --- 10.10.10.20)
User PC IP
10.10.10.21/24
GW 10.10.10.20
Topology
Sw1--------------trunk----sw2--------trunk-------sw3
if for some reason Sw1 becomes root bridge for vlan 10 instead of Sw3 will User PC able to ping the gateway?
We had issue today where Sw1 become root bridge with lower priority then SW3 and users were unable to ping the default gateway.
Mahesh
Larry Sullivan
Level 7
Level 7
Sounds like you answered your own question, or at least the situation did.  Does SW1 have a default GW?  Also, why not prevent SW1 from ever becoming the root in the future?
SW1 has default route to managment network only.
Topology change happened as someone from server team connected the server/switch to one of the ports on the SW1
rais
Level 11
Level 11
There aren't any loops in your L2 diagram. I wonder how would the topology change even if any of the switches becomes root.
Thanks.
