Comparaison between IOS
Ahmed Zniti
Community Member
Can u ask me about the difference between the ios version 12.2(44)SE2  and 12.2 (55) SE9 and the bug fixed relative to the old version12.2(44) from cisco catalyst 2960 24 PCL
Ahmed
Ahmed,
Yes go ahead and upgrade to 12.2(55)SE9 version.
Inayath
*****Plz dont forget to rate the posts.
InayathUlla Sharieff
not sure if I understand your question correct.
Anyways here is the cavets of bug fixed on 12.2(55)SE9:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/release/notes/OL23054.html#pgfId-1109143
Thank u Insharie for your help
do u recommand  that i make the upgrade to 12.2(44) SE2 from 12.2(55)SE9 ?
Ahmed
Ahmed,
Inayath
I second Inayath.
Upgrade to 12.2(55)SE9 as it's more stable than what you are currently using.
