Compatibility WS-C3750X-24S and GLC-FE-100LX
Vladimir_K
Dear colleagues! Could you share your ideas, about this issue of incompatibility between WS-C3750X-24S and GLC-FE-100LX.
According to the compatibility matrix WS-C3750X-24S is compatible with GLC-FE-100LX, starting from 12.2(58)SE1 IOS release. But, in my case, the switch gives the message (see the attachment). Could you share your ideas? Thanks in advance
L2SW01#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE5,RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 25-Oct-13 12:38 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE, RELEASE SOFTWRE (fc1)
L2SW01 uptime is 9 weeks, 2 days, 20 minutes
System restarted at 03:27:31 UTC Wed Mar 30 2011
System image file is "flash:/c3750e-universalk9-mz.150-2.SE5/c3750e-universalk9mz.150-2.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-24S (PowerPC405) processor (revision A0) with 524288K bytes of emory.
Processor board ID xxxxxxxxxxxxxx
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : CA:00:44:5D:XX:XX
Motherboard assembly number     : 73-12554-12
Motherboard serial number       : FDOXXXXXX34
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-24S-S
Daughterboard assembly number   : 800-32786-02
Daughterboard serial number     : FDOXXXXX8VX
System serial number            : FDOXXXXXXV9
Top Assembly Part Number        : 800-XXXXXX-05
Top Assembly Revision Number    : F0
Version ID                      : V04
CLEI Code Number                : CMXXXXXXRD
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24S      15.0(2)SE5            C3750E-UNIVERSALK9-M
Mark Malone
should be supported is it a cisco banded sfp ?
Catalyst 3750-X Series
Network Device
Transceiver Model
Minimum Cisco IOS Release Required
WS-C3750X-24T
WS-C3750X-48T
WS-C3750X-24P
WS-C3750X-48P
WS-C3750X-48PF
GLC-GE-100FX
12.2(53)SE
With C3KX-NM-1G and C3KX-NM-10G
(slots 1 and 3) network modules
WS-C3750X-12S
WS-C3750X-24S
GLC-GE-100FX
12.2(58)SE1
Note: Client ports and uplink ports with
You could try these commands........service unsupported-transceiver ....no errdisable detect cause gbic-invalid
Thanks! I will try and feedback later
