Compatibility Issue Between Cisco Switch and Access Point
SunnySingh54887
Hi Cisco Community,
 I want to know that does Cisco Switch SG350-28MP-K9-EU (CISCO SG350-28MP 28 Port Gigabit POE Managed Swtich) supports Cisco Access Point AIR-AP1562I-D-K9/ AIR-AP815W-D-K9 Series or not?
Waiting for your quick response.
5 Replies 5
Mark Elsen
 - Lookup the datasheet for the particular AP-model (google on it) , and look for power consumption information. Then check if the switch can provide sufficient power, using the same  methodologies.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
According to the data sheet, SG350-28MP supports 60W PoE on 4 ports.  The 1562I will benefit if they are connected to one of these ports.
Thanks Leo,
You mean to say that only 4 AP 1562I can be connected successfully to SG350-28P switch which has 60W of I/O Power. Right?
Can you pls share me the detail of 4 ports of SG350 which supports AP 1562I....or can you share me datasheet as I am not able to find it...
Thanks Leo,
Yes as per datasheet 4 ports of SG350 supports 60W of I/O Power.
