07-12-2007 07:35 AM - edited 03-05-2019 05:15 PM
What memory does the 3745 use? Do I need to buy cisco or can I use something like this:
Standard 32M X 64 Non-ECC 133MHz 144-pin Unbuffered SODIMM (SDRAM, 3.3V, CL3, Gold)
07-18-2007 12:42 PM
The Cisco 3745 Multiservice Access Router has two Small Outline-DIMM (SODIMM) memory slots on the motherboard. Each slot can hold one of these memory sizes:
? 64 MB
? 128 MB
? 256 MB
For information on the part numbers, refer http://www.cisco.com/en/US/products/hw/routers/ps282/prod_bulletin0900aecd8021b738.html.
07-18-2007 01:04 PM
This link might Help.
Also go through this post where the user has successfully used a non cisco memory
HTH, rate if it does
Narayan
