Competitive Guide
fersaldana
Community Member
Do anyone know if there is a pdf file where you can see the competitive information for switches cisco vs hp, 3com, nortel, etc
5 Replies 5
sachinraja
Level 11
Level 11
am not sure if there is a doc like this.. We normally used to refer the datasheets of the switches, and find the technical and hardware differences between the switches.. am sure you can do the samething and try to develop competetive information..
HTH.. all the best..
Raj
andrew.burns
Level 11
Level 11
This information is only available to Cisco partners, from "Partner Central".
Andrew.
I am a partner do you have a link to it
After you log in to the Partner Central go to Sales and in there you'll find a whole section called "Competitive Edge Portal". Everything you need is there.
Andrew.
